Old 01-29-2024, 01:38 PM   #1
FastEd
Drives: 2018 ZL1 1LE
Wheel Hop M6
Hi everyone,
Looking for some insight I have 6th gen SS M6. Experience real bad wheel hop on prepped surface. Currently riding on Yokas AD09s, more of track tire rather than drag . From there upgraded to BMR cradle bushing lock out kit and lower trailing arms. Still same wheel hop. Have to baby the throttle or I hop violently. Any suggestions? Continue with suspension upgrades?
FastEd is offline   Reply With Quote
Old 01-29-2024, 03:14 PM   #2
s346k
s346k's Avatar
Drives: like an old lady
put a drag tire on it if you want performance at a drag strip
Old 01-29-2024, 06:33 PM   #3
cjperformance
cjperformance's Avatar
Do you have stock tire sizes?
DSX Aux Low Side | LT4 high side | Flex Fuel
TooHighPsi Port Injection (installed & tuning)
CircleD 3K Stall | QA1 CF Driveshaft
Forgestar F14 Drag 17x10 NT555R2 305/45/17 Rear
Forgestar F14 18x8 NT555G2 235/50/18 Front
10.84@131 w/4.13" pulley
??.??@??? w/3.7" pulley (installed & tuning)
Old 01-29-2024, 07:54 PM   #4
FastEd
I just upped the rear for staggered look 285/35R20
Old 01-30-2024, 08:22 AM   #5
cjperformance
Assuming the stock tire for yours was the 275/35/20 then that shouldnt be a problem. I had what i first thought was wheel hop, but it was very likely some computer shenanigans due to having non-compatible tire size combo. But a 285/35 is only about .2" larger.
Just curious what power level you are at?
Old 01-30-2024, 09:03 AM   #6
DevilsReject97
Nightmare
DevilsReject97's Avatar
Drives: Your mom crazy in bed
1.) Consider getting a true drag radial, as it would actually be more beneficial to your launch as opposed to the street tire. If nothing else, consider looking at an R888R or something similar as that's still better than your typical street tire.
2.) If you're drag racing on street tires - drive around the water box and do a quick spin of the tires to clear debris. Don't waste time with a burnout because it isn't beneficial and you'll just help spread water everywhere, most likely pissing some folks off.
3.) Lower the tire pressure on the street tires to about 30lbs, and drop about 2 lbs every time until you find that "happy" place. Every car will have a different one due to the type of tire/power/etc...
I'm sure there's something I've missed...
Old 01-30-2024, 07:15 PM   #7
FastEd
Yes it was. I looked it up before upped a size, I am well within 3% balance. I am at 462WHP/488WTQ.
Old 01-30-2024, 07:21 PM   #8
FastEd
That's what I do. I drive around the water box. I do have decent track tires Yokas AD 09s. Just not drags, next set will be Nittos 555R2. I tried to lower pressure once, I drive car to the track. Didn't help and I was far from home as we have only few tracks in a whole province so no air compressor to pump it back up.
Old 01-30-2024, 07:54 PM   #9
DevilsReject97
Nightmare
Invest in one of these puppies, or find a similar one...they pretty much come standard in the Camaro ZL1... would allow you to inflate/deflate the tires as needed.
The 555r2 is a solid choice as well for track duty..
https://www.ebay.com/itm/12627848943...MaAnD4EALw_wcB
Old 02-08-2024, 01:51 PM   #10
asthmamax11
asthmamax11's Avatar
You really need sticky tires for a modded 6 speed
I'd even say get a real drag pack at least for the rear.
18" with rrrII's or mickey thompsons
16 1SS M6 White
Magnuson 2.3 Heartbeat
Roto Fab
Hurst short shifter
#'s coming soon
Riaction coilovers
1LE sway bars
BMR mm
BMR chassis brace
02 Z28 M6 35th anniversary
80k miles
T-tops
Leather
Bolt ons
Daily Driver
