Old 01-27-2024, 12:02 PM   #1
havelegs
havelegs's Avatar
Drives: 24 LT1 M
2024 LT1 front brake pads part number?
Guys I'm seeing different results for 2024 front pads as there seems to be a slight change in the pad. They are no longer held in by pins, rather a torx screw.
Does anyone know the part number from GM or Powerstop?
24 LT1 M6 Sharkskin Metallic
22 Mazda CX-30
havelegs is offline   Reply With Quote
Old 01-28-2024, 07:06 PM   #2
dpevans
Drives: 2024 Riverside Blue 2SS 1LE
must be a secret, you'll probably have you take your brake RPO code to the parts counter at a dealership and have them look it up. I was looking for track pads and no one has released 2024 info that I could find. Luck has it mine 2024 are the same as the 23 SS1LE.
dpevans is offline   Reply With Quote
Old 01-28-2024, 08:51 PM   #3
Bumbleboy92
Long hauler
Bumbleboy92's Avatar
Drives: 2022 Camaro 2SS 1LE
Do you have 6 Piston Brembo's? If you can PM me your VIN I can try to find out what RPO you have
2016 1LT v6
- Totaled
Happiness: Infinite
Old 02-04-2024, 02:47 PM   #4
turbojeep95
turbojeep95's Avatar
Drives: 17 Camaro lt, 22 Camaro LT1
You have the california compliant brake calipers. They are 4 piston brembos but get one's that fit a c8 corvette with the z51 package. I pulled these off rock auto so they should give you a good place to start.
-POWER STOP Z238009 Z23 Evolution Sport
-POWER STOP 178009 Z17 Evolution
-POWER STOP Z268009 Z26 Street Warrior
-Hawk DT60 HB926G.577
turbojeep95 is offline   Reply With Quote
Old 02-05-2024, 03:33 PM   #5
havelegs
havelegs's Avatar
Drives: 24 LT1 M
thank you
22 Mazda CX-30
Old 05-05-2024, 12:06 PM   #6
wintertopdown
Drives: 22 Convertible V8 LT1
Pardon me, not to highjack your thread but I have a 22 and am trying to find the right pads. My local dealer is back ordered and my local auto parts stores don’t have the correct sizes. Is this the correct part #?
https://www.gmpartsoutlet.net/oem-pa...-pins-85142439
I bought my first 6-Speed convertible Camaro in November 2018 and now drive a Hot Red V8 LT1 M6.
My Windows Sticker: https://cws.gm.com/vs-cws/vehshop/v2...FE3D78N0129849
wintertopdown is offline   Reply With Quote
Old 05-11-2024, 09:06 AM   #7
turbojeep95
Try this part number, 85529064. Looks like those are SS pads. You want the corvette z51 brake package pads.
