Old 01-26-2024, 09:18 AM   #1
z28pat
z28pat's Avatar
Drives: 2002 z28, 2018 2ss 1LE
Tow hook hole cap?
I got my zl1 preowned and I’m wondering if I’m missing something.
Is there supposed to be a cover or cap covering the hole where the front tow hook goes?
Thank you
z28pat is offline   Reply With Quote
Old 01-26-2024, 09:45 AM   #2
CalgaryZL1
CalgaryZL1's Avatar
Drives: 2020 Chevy Camaro ZL1
My 2020 doesn’t have a cover of any sort
Old 01-26-2024, 09:59 AM   #3
VORTEX1
VORTEX1's Avatar
Drives: Camaro ZL1 , Corvette ZO6
No cap provided
I tell unsuspecting observers that I have a "James Bond" clone and that is my machine gun access . Seriously , my car when new never came with a cap over the tow hook mounting point .
VORTEX1 is offline   Reply With Quote
Old 01-26-2024, 10:37 AM   #4
ZPirate
ZPirate's Avatar
Mine did not come with a cap/cover either. I put a tow hook in it!
2003 Nissan 350Z (modified)
2009 BMW 135i (Sold)
Old 01-26-2024, 11:12 AM   #5
z28pat
z28pat's Avatar
Thanks everyone, time to find someone with a 3D printer who can make one then.
Old 01-26-2024, 11:29 AM   #6
Deacon Blues
Drives: 2024 Camaro 1SS M6
On a related note, can the tow hook that comes with the car be left installed, or should it be removed when not in use? I know it isn't the most aesthetically pleasing compared to aftermarket tow hooks, but I'd rather install it and then have it in case I need it rather than try to put the thing on in an emergency.
Deacon Blues is offline   Reply With Quote
Old 01-26-2024, 05:18 PM   #7
CalgaryZL1
CalgaryZL1's Avatar
Absolutely you can leave it installed. It’s no different than any aftermarket. Just make sure it is secured properly.
Old 01-26-2024, 06:16 PM   #8
Vigilante375
Drives: 2018 Camaro ZL1
None of the year model ZL1s came with a cover for that.
Old 01-26-2024, 06:41 PM   #9
CalgaryZL1
CalgaryZL1's Avatar
OK who has a 3-D printer? Let’s create one that has the ZL1 or panther logo on it, I bet we sell 350 at least!
Old 01-27-2024, 06:56 AM   #10
Deacon Blues
Many thanks! The manual is curiously sparse on this, so I appreciate the insight.
Would blue loctite be recommended on those threads to keep it in place?
Old 01-27-2024, 01:44 PM   #11
Vigilante375
The manual doesn't say anything about this because GM, and most people, see this as a only need to use when I need to use it kind of thing.
Old 01-27-2024, 04:53 PM   #12
CalgaryZL1
CalgaryZL1's Avatar
Yes, blue Loctite would work and also if the threads are long enough to allow you to add a nut (jam nut ) that allows you clock the eyelet where you want it when it’s tight.
Old 01-28-2024, 08:24 PM   #13
z28pat
z28pat's Avatar
Here’s what I’m thinking, this is a cheap plastic cap I cut up to make a mock up. I’m going to look for a 3D printer person that can make it fit in there so it won’t fall out
