Emerald Coast Camaros
Drives: 2017 50th Camaro LT2/RS Join Date: May 2011
2017 V6, Auto Rearend Pumpkin Change
I have a V6 and have highway noise had the dealer check it out and they said i would need a new diffrential, put it on and lift and checked it at hwy speed and listen with a scope, Quoted me 3800 to change it. So my question is for a V6 Auto do i have the dif cooler that cools the diff with the trans fluid. (no i have not looked) to see if the lines are there. So if it does not can i change it to the LSD that the V6 Manual has with no issues. The diff from gmparts direct is 1599 and the LSD is like 2200. I can get a used on for 500.00
Also has anyone replaced there pumpkin, From what i have seen there are 12 axle bolts, 3 drive shaft bolts and 3 carrier bolts. Am I missing anything.... I can do it on a lift with no problems. Are there any "special tools".. Please advise
2017 LT2/RS, 50th addition. Airaid CAI, Solo Performance Axle back, sunroof, Smoked Led Markers
#2 | |
Long hauler
https://www.camaro6.com/forums/showthread.php?t=584316
No oil cooler, you’ll need a tune but it works
2016 1LT v6 - Totaled Happiness: Infinite |
![]() ![]() ![]() ![]() Drives: 2024 Riverside Blue 2SS 1LE Join Date: Mar 2016
The auto and the manual have different gearing. I have seen other post where you cannot change the gear set so it's impractical.
#4 | |
It can work
If i keep the stock non LSD then finding the carrier, axle e torque bolts become an issue from what have looked so far they are not being made any longer and they are susposed to be a one use bolt. I'm still thinking, I have other cars to drive so I'll give it some thought....
