![]() Drives: Chevrolet Camaro zl1 Join Date: Dec 2023
Rear tire size
Hi,
Can anyone tell me if 345/30/19 will fit on a 2019 ZL1? They are 27.1 inches tall & the stock 305/30/20 are 27.2 inches tall so it’s the width that concerns me. The offset is +41. 19x12. |
PKG4U
Yep.. some will tell you it’s fine but most recommend moving the wiring harness located in the rear driver wheel well behind the fender liner. From the factory it sits at a possible rub point so if you move it higher up in the well, it doesn’t rub.
2020 Camaro LT1. Bought 10/2020 | GM PERF. CAI | GM Muffler Delete (Performance Exhaust 4” tips). | SOLD 1/2022|
2018 ZL1 Summit White | Bought 1/2022 | PDR, Recaros, Carbon Dash, WeaponX Hx System, Apex SM-10 in ZLE fitment w/PS4S Mods after Warranty “Imma keep it stock” ![]() |
Having FUN in the SUN...
Drives: 2022 M6 ZL1 1LE Join Date: Jan 2022
Worked for me... Although I upgraded to the APEX SM.10's the wheel sizes are the same...
2022 M6 ZLE: Katech Standard Ported Blower + Ported Heads + 103mm TB + Oil Pump + C5R Chain + Valve Covers + Coil Relocation Kit
TSP VVT and DoD Delete Covers + LME Chain Guide + DSX Billet Lid + ATI Damper + 9.17" Lower + 2.4" Upper + MM Wild Catch Can Coated AR Headers + GESI UHO Cats + V Bands + AWE Touring + Magnaflow Center X + MSD Coils + Banks iDash + JMS Booster ALL the BMR Read End Goodies + BMR Motor Mounts + JRE Terminator Cam Package + Big Gulp + GMS High Flow Crash Bar DMS Front HX + Fender Tank + FIC 30's + APEX SM.10's + TOYO 305/345 R888R's = 770rwhp 815rwtq @E55 13.5psi |
Are they 19 inch? What do you have in the front? I want to get 305/35/19 for a bit mor ground clearance.
Yes, same size as stock...
19x11 up front wrapped in a 305/30 19x12 in back wrapped in a 345/30
