![]() Drives: Camaro SS Join Date: Apr 2022
2023 SS 1LE rear tire wiring harness
From what I understand GM has moved this harness so it's no longer a problem with getting rubbed through with track use on the newer cars is this true or still need to be moved?
![]() ![]() ![]() ![]() ![]() Drives: Chevrolet SS 1LE Join Date: Oct 2019
I think in some earlier cars it came loose, fell down and wedged itself in the cavity between the liner and sheet metal, and pushed the liner out into the tires of some 1LEs. Happened to my friend's 2020. I presume they've fixed that, but I'm not aware of them actually relocating the harness.
Matt Miller
2020 SS 1LE |
![]() ![]() Drives: 2004 BMW 330CI, 2022 1SS 1LE Join Date: Dec 2021
I had to move it on my 2022. I think it may be ok on stock wheels/tires but definitely not if you're going to go wider.
I would just move it if you want to track the car. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
I moved my 2022 SS 1LE harness
"KEEP THE FAITH"-Fbodfather |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
Word from the street is that some cars have not been moved, GM says they moved it, hard to know unless you look at YOUR car, it seems. My ZL1 was EO moved out of the way.
cool, thanks for the info. I will take a look at mine before tracking for sure.
#7 |
![]() Drives: 2021 SS 1LE Join Date: Mar 2023
Uh.. I've got a '21 SS 1LE .. where is this wiring harness? I'll go lookin for it next time the car's on jackstands..
#8 |
#9 |
2020 Shadow Gray 2SS
2020 2SS (non-1LE)... Left side rear wheel well...
BEFORE the move: AFTER the move: I went from stock 275/35/20 to 1LE spec 305/30/20 so I knew it wouldn't be an issue but since I had the wheels off either way, I figured the 15 minutes of effort was worth any possible issues later...
After delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Pedals, SS Wheel Caps, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF-Full Front & Rockers, 35% Tint, CeramicPro coated, RST Stainless Brake Lines, Castrol SRF, MSD Plug Wires, Mamo V3 Ported TB Left: My "fun" ride (455 HP). Right: My "work" ride (52,000 HP): a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph. BOTH AWESOME to operate... |
#10 |
Sweet, thanks! Will go poking for it next time wheels are off..
