Old 01-02-2024, 03:25 PM   #1
White1SS
White1SS's Avatar
Drives: White 2024 1SS M6
Rev Match
Is it normal for the Rev Match to rev when you take the car out of gear, before you shift into a lower gear? It's like it sometimes revs when in neutral, not even trying to downshift.
Thanks !
White1SS is offline   Reply With Quote
Old 01-02-2024, 03:44 PM   #2
Christian1LE
Drives: 2004 BMW 330CI, 2022 1SS 1LE
If it's just sitting there in neutral it's not normal but if you're putting it into neutral and maybe "jiggling" the knob it definitely will because it's trying to predict what you're going to do.
Christian1LE is offline   Reply With Quote
Old 01-02-2024, 03:57 PM   #3
24LT1guy
Drives: 79,97,02 z28
Mine does. I dont downshift to 1st but I get a rev for it as I'm slowing down. I find it weird it does that but I'm used to it now
24LT1guy is offline   Reply With Quote
Old 01-02-2024, 04:36 PM   #4
White1SS
White1SS's Avatar
Thanks guys. It's a 2024 and I have less than 300 miles on it, so I wasn't sure if it's a normal thing or not. Thinking about it, it does seem to be in the lower gears, I haven't really noticed it in higher gears. It's kind of a weird feeling when you pull the shifter out of gear, and it revs a bit before you even try to put it in a lower gear.
Old 01-02-2024, 07:51 PM   #5
m6-lt1
m6-lt1's Avatar
Drives: 2023 Chevrolet Camaro 2SS 1LE
Normal. I’m on my 2nd 6th Gen and both of them did it. Normally happens when I’m coasting to a stop and I shift to neutral. It thinks I want to go to first.
Current: 2023 2SS 1LE
Prior:
2016 Camaro 1SS
2007 Mustang GT
2008 Civic Si
m6-lt1 is offline   Reply With Quote
