jfkheat
Drives: 2023 ZL1, 2023 Challenger Hellcat Join Date: Nov 2023
2018 ZL1 Question
I have found a 2018 ZL1 that I like. How do I tell if is a 1LE car? It has the black wrapped hood and tall wing on the trunk. I realize that those could have been added. What else would I need to look at? What option codes are 1LE only?
Thank you, James |
![]() ![]() ![]() ![]() Drives: 2023 ZL1 Join Date: Dec 2022
Does it have the dive planes (canards) on the front end in front and there should be I think, some type of shock tower adjustments like 1LE's does under the hood? Also Red Brake Calipers? But I'm guessing!
Katech Track Day CAM 38%•BTR Dual Valve Springs•Johnson Lifters•Trend 3/8 Chromoly Pushrods• VVT Del•CNC Heads•AFM Delete• C5-R Timing Chain•Katech Oil Pump•Katech 112mm•Maggie 2650 3.25” Upper/ATI SD w/10.32” +20%•10 Rib Belt•RFBG•FI IC Stage 2•THPSI Port w/875cc Inj•Katech Dual Fuel Pump•DSX Aux Pump•SW 2" Headers w/Legend NPP•GESI UHO 4.5" CATs•Brisk RR14S Plugs•BMR Motor Mounts•BMR Cradle Lockout &Bushings Kit•BMR Rear Suspension & 15" Conversion•DSS 1pc DS•RPM 6-Point Roll Cage•10lb FireSense+ w/4Fire SFI 17.1 Fire Sys•Weld Forged Vitesse Rear 17x10 Beadlocks-Front 18x6•Unlocked TCM
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2023 Summit White Camaro ZL1 M6 Join Date: Dec 2021
The ZL1 1LE package includes:
Satin Black hood wrap 19 inch black wheels with Goodyear® Eagle® F1 SuperCar 3R 305/30R19 front and 325/30R19 rear, summer-only tires Visible carbon fiber weave hood insert Visible weave carbon fiber rear spoiler Performance suspension with DSSV™ dampers
2023 Dodge Durango SRT (daily driver) 2003 Nissan 350Z (modified) 2022 Rapid Blue 1SS 1LE M6 (delivered 2/19/22) (Sold) 2009 BMW 135i (Sold) |
jfkheat
Thank you for the responses. I don't think it is a 1LE car. It came with 20" wheels. Here are a couple pictures.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2024 CT5-V Blackwing Join Date: Sep 2020
Rarely do people swap the 19's for 20's. Many people add the aero components, but most people don't go through the trouble of swapping to red calipers though which makes me think its possible. Really need to open the hood to see the top of the struts for confirmation.
#6 | |
jfkheat
R0G - TIRES, 285/30R20 FRONT AND 305/30R20 REAR, BLACKWALL, SUMMER ONLY Here is an under hood picture. |
#7 |
Not sure those look right... but again, I'm not a 1LE expert either!
#8 |
Looks like a standard ZL1 with aero add-ons and red calipers.
#9 |
![]() Drives: 2018 NFG ZL1-1LE Join Date: Jun 2018
It is most likely not a 1LE. It is missing the bright blue adjustable camber plates in the pic. These would go with the bright blue multimatic shocks/struts that a 1LE would have. It is also missing the smoked rear tail lights. Another little thing to check for is the release to fold down the rear seats. On a 1LE it is missing to save weight. (Though this has been debated as the mechanism is still there.) Also, is it a manual or automatic transmission? In 2018, the 1LE package was only available with the 6-speed manual. The automatic was not offered until 2019 model year. A bit hard to tell in the pic but the front splitter and lower rocker panel seam to be to glossy. 1LE cars have these in a matte black. Regular ZL1’s have these in a higher gloss.
#10 |
It's definitely not a 1LE if it came with 20" wheels and 285/305 tires.
#11 |
![]() ![]() ![]() ![]() Drives: 2018 Camaro ZL1 Join Date: Aug 2018
In the engine bay you can clearly tell its a non 1LE. The top of the shocks isn't recessed and has that "cap" if you want to call it that on there.
Also the 1LE came with no rear set fold down pull tab. Even though the rear of the hardware is there GM didn't want to install the pull tab and can be easily added afterwards. |
#12 | |
jfkheat
Thank you all for your reponses. I still like the look of the car. I may check into it more. |
