Old 12-31-2023, 08:50 PM   #1
Camaro convert
Drives: 2023 Chevy Camaro 1LT Convertible
ooops!
I was in the drive thru in my one month old 2023 Camaro and I put some change on the console next to the shifter and it slid under my vent! Any way to retrieve it?
Camaro convert is offline   Reply With Quote
Old 12-31-2023, 10:25 PM   #2
MrDoz
Drives: 2024 Chev Camaro
Put it in sport mode and push the throttle all the way to the floor as fast as you can?
MrDoz is offline   Reply With Quote
Old 12-31-2023, 11:26 PM   #3
MagnumMaro
yikes, that spot is like the bermuda triangle! let it go man...
MagnumMaro is offline   Reply With Quote
Old 01-01-2024, 01:10 PM   #4
PostalLDMC
PostalLDMC's Avatar
Drives: 2022 2LT RS Convertible
You forgot to tell him to lock up the brakes so the change will slide to the front.
PostalLDMC is offline   Reply With Quote
Old 01-01-2024, 02:11 PM   #5
Winnie
Drives: 2019 Camaro 2SS
Had the same thing happen to me, 2 dollars worth of quarters disappeared in 5 sec., I was just hoping it wasnt causing problems wherever it went. ha
Winnie is offline   Reply With Quote
Old 01-01-2024, 03:45 PM   #6
Broooster
Drives: Sharkskin Metallic ZL1
Can't answer your question, but to prevent that from happening, I took a small black microfiber towel, cut it in half and placed it in front of my shifter. I used a zip tie to push the edge of the towel underneath the vents, looks pretty good.
Broooster is offline   Reply With Quote
Old 01-01-2024, 08:08 PM   #7
Camaro convert
Thanks everyone! It was only a dime and 2 quarters I hope it won't end up as a rattle or some other problem!
Old 01-01-2024, 10:23 PM   #8
It's the hidden built-in slot machine, if nothing came out when you dropped the coins, you didn't win
Old 01-01-2024, 11:56 PM   #9
GroundhogSS
GroundhogSS's Avatar
I got a piece of black tubing and ran it from side to side to block it off. This after my wife put a ring on the console and it slid through the gap. You can take the console up by removing some screws at the back under the front edge of the back seat.
Richard
Delivered: 08/15/2016
#TeamBeckyD
Old 01-02-2024, 06:18 AM   #10
Booher
Booher's Avatar
Drives: 2019 zl1 6 speed
Has anyone ever tried this out?
Linskip Center Console Storage Organizer
https://a.co/d/jbot1mi
Old 01-02-2024, 11:22 AM   #11
Winnie
Old 01-02-2024, 12:58 PM   #12
SamSmoothCastel
Drives: 67 Orange Mustang Coupe
losing change in the car is typically a problem for corvette owners.
SamSmoothCastel is offline   Reply With Quote
Old 01-02-2024, 08:34 PM   #13
paradigm
Drives: 2022 Camaro 1SS 1LE
Interesting - never seen that before. I put pockets on the side of the trans tunnels for storage:
https://www.amazon.com/gp/product/B0...0?ie=UTF8&th=1
paradigm is offline   Reply With Quote
