Old 12-29-2023, 01:51 PM   #1
zedts1986
zedts1986's Avatar
Drives: 2024 2SS 6MT
Break-in oil change: oil lab analysis
So, of course there’s nothing in the manual indicating that a break in oil change is necessary, but like most others, I saw it as cheap insurance. My goal was to do the first change at 1500 miles, the next at 5000, and then every 5000 after that. Also did the diff fluid at 1500 and plan to at 5000, but then not again until much later in the cars life, but all that is irrelevant to this post.
I ended up getting to change the engine oil at 1685 miles and sent it into Blackstone Labs for some analysis. Thought I’d share the report with you guys.
I’ll follow up with another test around the 5000 mile mark and see how things have changed.
Current: 2024 Camaro 2SS M6, Red Hot, Ceramic White interior, Dual Mode Exhaust, Magnetic Ride Control
Old & Sold: 2019 Camaro 1LT M6, RaceChip GTS, RaceChip XLR, ZZP Catted downpipe, JacFab Boost-o-lator, K&N drop-in air filter, ZZP Intake Tube, PTP turbo blanket, NGK 6510s gapped at 0.022"
Motorcycle enthusiast
zedts1986 is offline   Reply With Quote
Old 12-29-2023, 03:12 PM   #2
CalgaryZL1
CalgaryZL1's Avatar
Drives: 2020 Chevy Camaro ZL1
I would do a 3800 change just to see how it compares to the universal post Breakin average.
Old 01-22-2024, 05:06 PM   #3
haggler
haggler's Avatar
Drives: '23 2SS RSblue 6MT, sold '19 ND2
I have one to add. Oil was changed at 700miles with M1 ESPx3 0w40. This interval is over 11 months with 3364 miles. Total miles on vehcile is 4114:
'23 2SS, 6 speed, NPP, Copper-free brakes, 56V Carbon Flash Rims, Riverside Blue
1LE sway bars
EOS front splitter
5-6-22:1100,
7-19-22: 3000,
8-3-22: TPW 8/15/22,
10-4-22: ETA 10/13/2022
10-15-22 6000
haggler is offline   Reply With Quote
Old 01-22-2024, 11:05 PM   #4
CTRifecta
CTRifecta's Avatar
Drives: 2SS 1LE
Looks like the factory fill is really just m1 0w40 and doesn't have any extra moly or anything. Interesting. OP, how hard did you drive during that OCI?
2024 2SS 1LE | 6MT | Riverside Blue
1100 - Order submitted - 7/12/23
2000 - Order accepted - 8/22/23
Vehicle Built (per chevy chat bot) - 10/10/23
Window sticker available online - 11/4/23
Arrived at dealership - 11/10/23
CTRifecta is offline   Reply With Quote
Old 01-23-2024, 11:15 AM   #5
The Chief (tm)
The Chief (tm)'s Avatar
Drives: 2016 Camaro 2SS "Convertibobble"
Reading this thread has me asking myself how I managed to do a Blackstone analysis at my first oil change, but...somehow...forgot to keep a sample at the second one, for comparison.
'16 2SS Garnet Red ~24K
"Mods": GM wind deflector, home-made rear seat delete & platform, not-quite garnet red key fob cover (+10rwhp)
'99 4Runner 367K
'94 ST1100 146K
The Chief (tm) is offline   Reply With Quote
Old 01-23-2024, 01:01 PM   #6
S1lent
S1lent's Avatar
Drives: 2023 Chevrolet Camaro 1SS
Here's the data from my first three oil changes.
S1lent is offline   Reply With Quote
Old 01-24-2024, 11:52 AM   #7
zedts1986
zedts1986's Avatar
I mostly followed the suggested break-in. Under 4000 rpm, under 80 mph, no heavy down-shifting, no lugging the engine. I'd say that was 98% of the time. There was a time or two where I "accidentally" went to 5000-5500 rpm.
I'll be doing another sample at 5000 miles (on the car...so around 3400 miles on the oil).
Old 01-30-2024, 11:38 AM   #8
RallyRunner
Drives: 2020 RG LT1 M6 / 2019 4runner
honestly, this is looking perfectly fine for a fresh engine. Copper is always high for the first 10-15k miles, and will settle down to single digits. Silicon is found in liquid gasket material and fine particles, this is totally normal for a recently assembled engine. Your steel (iron) valvetrain parts are seating in and aluminum/chrome is your pistons and rings. I don't see anything at all to be concerned about with the other wear metals.
don't put too much stock in Blackstone's implied Flashpoint, its not actually physically tested but derived from an equation they run based on mileage vs expected viscosity. in reality with any DI motor it'll have a higher degree of fuel in the oil than port injected, but its nothing to get concerned about if you stay well within recommended oil change intervals.
don't put too much stock in analysis like these until you've got about 15-20k on the engine, at which point your wear metals will level out and act normal due to the engine being fully broken in. in my other car (4runner) it took nearly 40k to level out! keep on keepin on!
RallyRunner is offline   Reply With Quote
Old 09-11-2024, 11:23 AM   #9
zedts1986
zedts1986's Avatar
Ran the oil about 6300 miles and just did the change last week and sent it in for analysis. Should get that back within a month or so.
I did do the differential oil again (first at 1695 miles, this at 8000 miles) and it looked like brand new oil. Still glad that I did it for peace of mind. I had all four wheels off of the ground for oil change and tire rotation, so it took an extra 10 minutes to change the diff fluid. I'll probably do it again sometime before the suggested 45k miles, but I'm not going to worry about it much moving forward.
