![]() Drives: '23 1SS 1LE-Sharkskin M6 Join Date: Apr 2022
1LE Owners, need your input
Probably in the wrong section, but this area gets the most traffic. All my 1LE owners and ZL1 guys, what product are you using to clean and revitalize your Alcantara parts? Steering wheel, shifter etc..... After a few months my high traffic parts are looking shoddy and I need your help. Thanks
#2 | |
![]() ![]() ![]() ![]() ![]() Drives: 2020 Chevy Camaro ZL1 Join Date: Apr 2023
![]() ![]() Drives: 2015 Camaro Z/28 Join Date: May 2009
I use Sonax on my Alcantara. It works excellent.
2015 Camaro Z/28 - Red Hot
1978 Trans Am Y88 Special Edition 400/4 speed 2001 Mecham Trans Am #3 - 7.0L LS1 |
Sonax works well also any rinseless wash product that has no protection(DIY rinseless, Owners Pride, ONR blue, Mckees N914) mixed to its proper dilution on a damp MF towel to clean and last I also use DIY interior clean and protect. After any of these 3 you wanna use a textile brush to fluff the fibers back up.
When driving it in the summer. I usually clean the steering wheel and shifter once a week I have the colorlock version but this is basically the same thing https://www.amazon.com/Geist-Upholst...86&sr=8-2&th=1
2022 1SS 1LE 6M in Riverside blue
Found exact build local- ETA 7/31/22 New ETA - 7/26, 7/30, 7/31, 8/1, 8/8, 8/15, 8/21, 8/28, 9/17 8/24. IT HAS ARRIVED at the dealer 8/25- It is in the Garage ACS ZL1 Sideskirts, 20% tint, CAI Intake |
#5 | |
![]() Drives: Car Join Date: May 2023
I plan on doing the same thing. I'd like to also use the regular leather SS shift knob + boot. Anyone know if they're compatible with the 1LE's short throw shifter? |
I use KochChemie Pol Star with the proper 1:5 to 1:20 (depending on area needing cleaned) solution with a foaming spray bottle and microfibre mitt or cloth. It does a good job of cleaning up the wheel, seats etc.
https://www.koch-chemie.com/us/products/pol_star
PRIOR CAR:
17' Camaro 2SS A8 Vert Upgrades: Pray MSD IM/95mm TB/E85/Tune / Roto-fab CAI / GM Dark Taillights / LED Turn's with VLED Resisters / LED Reverse Lights / JWM Side Markers / Factory UQT PDR (CTS-V) / BMR DSL, MM010 / TSP 1 7/8 / Front Camera / Eyebrow Harness / Elite Engineering E2-X / AEM Wideband with Aeroforce single pod / HD Radio / OnStar Delete / RPM Roll Bar |
#7 |
![]() Drives: 2023 2SS 1LE Join Date: Dec 2022
Sonax is great for cleaning the steering wheel and shifter and any other Alcantara parts. A great tip, is always have a suede brush in your car, like the glove box. After a drive, brush all the Alcantara touch points. This helps with drying and let's you go longer between cleanings. In the summer I do a deep cleaning about once a month. Winter times I can go longer.
2023 Riverside Blue Metallic 2SS 1LE Camaro
2021 Black Hyundai Veloster N -Sold- 2016 Grey Chevy Volt -Sold- 2018 Blue AWD Kia Stinger GT2 -Sold- |
#8 |
USCG Retired (MKC)
Drives: 2018 2SS 1LE Black Join Date: Aug 2018
I purchased a 2SS leather steering wheel from a member here and swapped the shift knob with a Speed Dawg, I use Sonax on the seats. I'm forever scratching and cutting my hands and was paranoid with the fuzzy steering wheel and shifter, didn't care for the feel either.
#9 |
Tri-County Camaro SWFL
On my 2013 I use Adam's interior cleaner, spray it on a microfiber, rub the steering wheel to get out any dirt. Use an interior brush to fluff the fibers back up then vacuum the wheel. Haven't had to clean the 22s interior yet but I would use the same method. I don't have the original shift knob anymore, installed an MGW. I only vacuum the boot.
#10 | |
![]() Drives: 2021 ZL1 A10 Join Date: Apr 2019
#11 |
![]() Drives: 2023 Camaro 1SS 1LE 6MT Join Date: Nov 2023
I haven't had to actually clean them yet, but good tips for when I eventually do need to.
All I've had to do is vacuum so far. I have this Makita "vehicle" vacuum with all sorts of attachments, one of which seems to work great on the suede. Gives you that fresh detailed sorta look. |
#12 |
I use the Sonax foam Alcantara cleaner too. I use 2 WHITE washcloths. First one I get pretty damp and wipe down all my Alcantara. Apply the foam scrub it in lightly and let it sit 10mins, hit it again with brush and wipe down with clean part of cloth(obviously
. I do same thing again and after wipe down with only slightly damp cloth I let it dry pretty good hit with clean dry brush to stand fibers back up and brush again when its completely dry. Works great for me. Stuff gets filthy even taking care to never have dirty hands and drive the car. The Sonax cleaner gets good results imo but its all ive ever tried.
#13 |
![]() Drives: Camaro ZL1 1LE M6 Join Date: Mar 2023
I use Sonax as well, and just follow the directions. I also use a Alacantra brush I bought at Wally World, brush everyting at the end of the drive before putting it away, especially the steering wheel and the shift knob.
ZL1 1LE
#14 |
