Old 12-26-2023, 09:09 AM   #1
2023_ZL1-AUTO
2023_ZL1-AUTO's Avatar
Drives: 2023 ZL1 - Beast Build
Corsa XTreme wNNP (no actuators) [ITEM SOLD]
ITEM SOLD
Katech Track Day CAM 38%•BTR Dual Valve Springs-Johnson Lifters•Trend 3/8 Chromoly Pushrods• VVT Del•CNC Ported Heads•AFM Delete• C5-R Timing Chain•Katech Oil Pump•Katech 112mm•Maggie 2650 3.25” Upper & ATI SD w/10.32” +20%•10 Rib Belt•RFBG•FI Interchiller Stage 2•THPSI Port w/875cc Inj•Dual Drop In Fuel Pump•DSX Aux Pump•Stainless Works 2" w/Legend NPP Axle Back•GESI UHO 4.5" CATs•Brisk RR14S Plugs•BMR Motor Mounts•BMR Cradle Lockout/Bushings Kit•DSS Chromoly DS•RPM 8-Point Roll Cage•10lb FireSense+ w/4Fire SFI 17.1 Fire Sys•Weld Forged Vitesse Rear 17x10 Beadlocks-Front 18x6•Unlocked TCM
Old 01-06-2024, 11:06 PM   #2
rllygrn.zl1
Drives: 2020 Camaro Zl1 Rally Green A10
Can you please explain the no actuators part? Wouldn’t it come with them being the NPP exhaust?
rllygrn.zl1 is offline   Reply With Quote
Old 01-08-2024, 04:22 PM   #3
CrazyIvan
Drives: Cadillac CTS V
You just mount your oem actuators on the Corsa exhaust.
CrazyIvan is offline   Reply With Quote
Old 01-11-2024, 10:13 AM   #4
2023_ZL1-AUTO
ITEM SOLD
