Old 12-24-2023, 04:26 PM   #1
WiggyB
WiggyB's Avatar
Drives: 2022 Camaro 2SS 1LE
Setup my LC-2 Digital Wideband O2 Sensor
So I have my wideband sensor setup and was able to configure it in HPTuners to have realtime readouts. The problem is I think its reading at 1/2 of what it should be. Could the formulas I'm using be wrong?
Here's what I currebtly have set for them both:
AFR (input/68.05) + 7.36 = output
EQ Ratio (Lambda :(input/1024) + 0.5 = output
Anyone have something else you're using currently?
d1sc w/ stage 2 intercooler, Lt4 fueling, JMS BAP, lt2 intake, mamo ptb, kooks 1/78 longtube headers w/ h/f cats, alky meth kit, thpsi port injection
WiggyB is offline   Reply With Quote
Old 12-25-2023, 11:19 AM   #2
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Curious as to why you didn't go with the tried and true AEM 30-0334? That is what 90% use on this platform.
KingLT1 is online now   Reply With Quote
Old 12-25-2023, 12:37 PM   #3
WiggyB
WiggyB's Avatar
This one I'm able to link to my P3 gauge instead of buying another gauge to hookup.
Old 12-26-2023, 08:43 AM   #4
Megahurtz
Snackbar Tuning
Megahurtz's Avatar
Drives: 2023 SGM ZL1
https://forum.hptuners.com/showthrea...da-Scanner-3-0
This thread might be helpful. I haven't messed with any LC/LM widebands in years since the AEM OBD2 unit came out. But I do recall there was some extra work required to get it to work and report properly.
Old 12-26-2023, 03:05 PM   #5
WiggyB
WiggyB's Avatar
I was looking at this link last night but didn't read deep enough. I looked further and used some pointers and did a little thinking. What I did was monitor the lambda on logworks (the software innovative uses) and played with the math on HP Tuners until I had them both matching. The screenshot attached is the math I used to get it working but the readings look good to me. I'll let you decide on that one though.
Old 11-12-2024, 08:08 PM   #6
tortilla-flats
tortilla-flats's Avatar
Drives: 2023 Camaro 2SS
@WiggyB any updates on your setup. This is the direction I'd like to go. I really don't want a pillar mount gauge or an extra gauge plopped on the dash somewhere. I really like the slick installation setup with this, plus the fact that it can be hardwired into the OBD2 connector.
tortilla-flats is offline   Reply With Quote
Old 11-13-2024, 03:50 PM   #7
WiggyB
WiggyB's Avatar
Naw.............. I thought what was posted above was the answer but man was the car running rich. I gave up and went with the AEM. The problem was it kept reading lean so we kept dumping fuel into it and it was the exact opposite.
Old 11-13-2024, 03:55 PM   #8
tortilla-flats
Thanks. Was hoping you figured out some magic. AEM seems they way to go, especially if you need help as that is what everyone else is using. Path of least resistance and all that.
Old 12-31-2024, 02:09 PM   #9
BryanT2016
Drives: 2016 Chevrolet Camaro 2SS
I am going to use the obd2 AEM 334 i think and use the vent mount u can get online to put it in my ac vent.
BryanT2016 is offline   Reply With Quote
