Old 12-23-2023, 10:53 PM   #1
fj5gtx
fj5gtx's Avatar
Drives: 70 GTX, 06 Mustang, 22 Camaro LT1
splash guards for my 22 LT1
Want to save my rockers and rear bumper areas, so I'm considering adding splash/rock guards.
Which set would you recommend and why?
2022 CAMARO LT1 COUPE AT10
fj5gtx is offline   Reply With Quote
Old 12-23-2023, 11:06 PM   #2
SS_Don
SS_Don's Avatar
Drives: '22 Camaro 2SS
Did you search? There are already many threads on this subject.
'22 2SS | Wild Cherry Tintcoat | Design Package 3 | NPP | MRC | A10 | NAV | Ceramic Coating | Full Frontal PPF | New Hood and Side Stripes | Michelin PS AS 4 | Range AFM Disabler
Mishimoto Catch Can | Diode Dynamics side markers | Cold Air Inductions CAI | LLoyd Velourtex front/trunk mats with Camaro SS logo | Footwell Lighting | Umbra Sequential LED Taillights
ZL1addons Deluxe Rock Guards, Stealth Lift Pads, and Tow Hook | Escort MAXcam360c | Banks Data Pro and Pro gauges in ZZPerformance pillar pod | Paddle shifter extensions
SS_Don is offline   Reply With Quote
Old 12-23-2023, 11:08 PM   #3
This one gets my vote: https://www.camaro6.com/forums/showp...1&postcount=47
Product link: https://rokblokz.com/products/chevro...31480470306859
Old 12-23-2023, 11:46 PM   #4
Buellrider
Buellrider's Avatar
Drives: 2023 1SS 1LE
I went with the these and like them.
https://extremeonlinestore.com/colle...ards-mud-flaps
Buellrider is offline   Reply With Quote
Old 12-24-2023, 10:52 AM   #5
fj5gtx
fj5gtx's Avatar
I like the rear attachment and fit.
The fronts install by drilling holes, and the video mentions nutserts but seems like they include rivets? I'm wondering if the molding they are using is to accommodate side skirts due to the rocker gap as shown in the pic.
Old 12-24-2023, 10:59 AM   #6
fj5gtx
fj5gtx's Avatar
Nice utilization of factory config for installation, but I wonder if the metal clip is going to wear through the fender paint. They must be making back alot of their R&D due to the simplistic materials, just flat sheets cut out. Nothing wrong with simple.
Thanks for the link!
Old 12-24-2023, 01:43 PM   #7
ZPirate
ZPirate's Avatar
Lots of options. ZL1 Addons, ACS, arpad_m's favorite Rokblokz, and a few more. I have ACS rock guards and love them. They are molded and fit the car perfectly.
2003 Nissan 350Z (modified)
2009 BMW 135i (Sold)
Old 12-24-2023, 02:25 PM   #8
No worries Just wanted to mention that this was the one mudflap type guard that does not use metal clips at all, the front guards have a cutout that is pulled over the fender, so it's only plastic touching the paint, not metal. It is 100% reversible without any damage, both front and rear, no drilling extra holes or using claw clips.
Old 12-25-2023, 03:05 AM   #9
MakCamaro
Makis
MakCamaro's Avatar
Drives: 2020 Red Hot ZL1 A10
The Rokblokz are the ones I would suggest as well. They are easy to fit, great customer service, and 100% reversible if needed.
Old 12-25-2023, 04:14 PM   #10
fj5gtx
fj5gtx's Avatar
Maybe they've changed them. From their install video, about 2 minutes in... looks like that metal clip pinches the metal part of the fender.
Old 12-25-2023, 06:07 PM   #11
Aha, I see what you mean, that one is set up so the flat section of the clip is pressed against the fender. You're right in that there is some metal to paint connection, even though it's flat clip backside against a large fender surface area.
However, others use a "claw type" trim clip in the top front attachment position where whose slipback prevention "fangs" of the clip (see red arrows) clamp into the fender, instantly scraping the paint off no matter how carefully you install it, while the Rokblokz has a notch in the plastic (green arrow) that is more gentle on the paint.
Old 12-29-2023, 09:28 PM   #12
Joelskidelahoya
Drives: 01 Z28 05 GTO 06 GTO 09 CTSV 21 1LE
do you have any pictures of these. i have it narrowed down to the ACS or EOS. I would like as much coverage as possible while also retaining the good look that is more aggressive than the stock. i am also considering give EOS 1le refresh side rockers a try with this splash guards. I have a blk 1le so i wanted all the parts to be flat blk.
Joelskidelahoya is offline   Reply With Quote
Old 12-29-2023, 10:30 PM   #13
pitrott1
OSCM(SW) USN Ret.
pitrott1's Avatar
Drives: 2023 Camaro 2SS-1LE VOM 6M
I went with the factory splash guards via GM/Chevy web site. Then sanded and used touchup direct for my color match. And had my dealer install and they are covered under gm warranty.
2023 2SS-1LE VOM, 6M, SR S-TBrace, A-PDL's, Fuzzy suede KP's, NAV
1100 3/29/23
2000 3/30/23
3300 5/1/23
3800 5/4/23
4200 6/1/23
6000 6/6/23
pitrott1 is offline   Reply With Quote
Old 12-29-2023, 11:56 PM   #14
nikerret
Drives: 2014 Ford F-350
I am a fan of the Rokblox I put on. I’ve noticed they stop a lot from hitting the paint.
2024 Red Hot 2SS 1LE w/BCD, PDR
2014 F-350 Crew Cab Cassis Cab Dually 6.2L w/4.30
2014 Hyundai Elantra GT
1995 Buick Roadmaster Estate
nikerret is offline   Reply With Quote
