Old 12-21-2023, 10:07 PM   #1
Matt1LE
Matt1LE's Avatar
Drives: 2020 3LT Camaro 3.6L 1LE
ProCharger on V6
Anyone here have a Stage 1 ProCharger on their V6 6spd? Wondering how the trans and diff is holding up with 400rwp?
Matt1LE is offline   Reply With Quote
Old 12-23-2023, 03:55 PM   #2
NiickySaz
NiickySaz's Avatar
Drives: 2023 Camaro 1LT V6
Man, you read my mind. I'm here to read similar input. I wanna get the edlebrock eforce and the trans is my #1 concern.
NiickySaz is offline   Reply With Quote
Old 12-23-2023, 07:02 PM   #3
Matt1LE
Matt1LE's Avatar
Yeah, I read that the Tremec 3160 has max torque 405 lbs. I was also wondering about the Rear Limited Slip and driveshaft. But I think they are the same as the SS.
Old 12-23-2023, 09:55 PM   #4
NiickySaz
NiickySaz's Avatar
I have the 10 speed. Atleast you know your limits idk what mine is capable. But I'm not looking to go wild I'd be thrilled with <380whp. I don't see the driveshaft itself being a problem. But I'm sure it wouldn't hurt to get one that is more sturdy.
Old 12-25-2023, 03:20 PM   #5
CYN_CRVR
CYN_CRVR's Avatar
Drives: 2023 V6 RS 6MT
The GT350 runs the 3160, and it's rated at ~530 hp / ~430 ft-lb (at the crank). Are they using special hardened internals? If not, I think the 3160 should have no problem handling a LGX with centrifugal supercharger at reasonable boost levels.
2023 V6 6MT: Riverside Blue, RS, Recaro, Brembo, NPP exhaust, GMPP suspension [view my build journal]
mods: BC Forged RZ21 19x10, Conti ECS 265/40, front splitter, FE4 front sway + endlinks, FEA rear sway + toe links
prior cars: NB Miata, C5 Z06, NC Miata
CYN_CRVR is offline   Reply With Quote
Old 12-30-2023, 11:35 AM   #6
Gen6cyl
Drives: Chevy Camaro 2021 ,rs, v6, manual
It looks like Tracy Lewis in Tampa is selling the lgx pro chargers from what I see on the overkill site. I got his occ system about 4 months, installing it today. In the past 1.5 years I have had I have had oil drain through my air filter and out the bottom of the box several times. The occ should keep the intake clean. I put one on my focus st years ago. I may post pics if anybody is interested.
Gen6cyl is offline   Reply With Quote
Old 01-01-2024, 02:17 PM   #7
CYN_CRVR
CYN_CRVR's Avatar
I'm interested. It requires you to drill into the intake manifold, right?
Old 01-01-2024, 05:57 PM   #8
Matt1LE
Matt1LE's Avatar
Stage 1 max boost is 7lbs. They claim no mods needed at that level of boost.
Old 01-01-2024, 06:52 PM   #9
Gen6cyl
Yes it's not that difficult. I have had the Tracy Lewis occ for 4-5 months, finished the install today.I watched his video on youtube many times. The one-way valves on the valve covers you pop out have 3 little ends that hold them in.Two broke off on one of them and one a one on the other . So 3 little pieces of plastic fell in the motor. I don't think it will be a problem. You have to drill the one way valves out of them. Other than that it went well.I think it will be good for the motor. I now have a good port to put crc valve cleaner in. I may use crc one more time. I had some oil in the intake as usual, glad to put a end to that. I will start a thread with pics soon.
Old 02-11-2024, 04:02 PM   #10
Nightfall18
Drives: 2018 v6 camaro ls
I'm getting ready to install a provharger kit ordered from phastek . But I'm ready from all the v8 guys about upgrading the map sensor to a 3 bar anyone know if this needs to be done on the v6 mine is a 2018
Nightfall18 is offline   Reply With Quote
Old 04-04-2024, 07:37 PM   #11
Start The Machine
Start The Machine's Avatar
Drives: 2016 M6 2.0T
Not the same at all. The GT has a much better cutch plate and flywheel combo and it has cooling. Our version of the 3160 is total garbage. The clutch slips easy with added HP and TQ and doesn't have the cooling function. When the clutch slips, It puts the car into a "limp-mode" that is actually dangerous IMO. You are going to have to upgrade to an aftermarket clutch from Clutch Masters or CLUTCH along with their lighter, compatible flywheels.
RS Package, HD Cooling Package, Brembo 6 Piston Front Brakes, SRP Racing Pedals, Soler Performance Throttle Controller, Dyno Tuned by Trifecta, Velossa Tech Ram Air, Mishimoto Intake, aFe Air Filter, Mishimoto Charge Pipes, ZZP 67mm Throttle Body, Trifecta T40 Stage 2 Turbo, JacFab Recirculation Valve, PTP Turbo Blanket, ZZP Catted Downpipe, Mishimoto Pro Cat-Back Quad Tip Exhaust, Mishimoto Catch Cans, Mishimoto Coolant Reservoir Tank, GM SEMA Grill, RPI Designs SS 1LE Front Fascia Extension, Ikon Motorsports 1LE Spoiler, American Authority ZL1 Side Skirts, AMPP Quad Tip Rear Valance
Start The Machine is offline   Reply With Quote
