Old 12-19-2023, 11:24 AM   #1
Ss7617
Drives: Chevy z06
Oil pump replacement parts to replace while apart
Hi I’m gonna have my oil pump replaced. Car has 7500 miles on it. What other parts should be replaced? Timing Chain /adjuster etc. car will remain stock but see track time. I’m not looking to spend extra money.
Thanks scott
Ss7617 is offline   Reply With Quote
Old 12-19-2023, 04:58 PM   #2
SOCAL.M6.ZLE
Having FUN in the SUN...
SOCAL.M6.ZLE's Avatar
Drives: 2022 M6 ZL1 1LE
Thats easy...
With the labor you will already have in it...
3 bolt cam Cam upgrade, LME dog bone, Katech C5R chain, ATI damper, 14% OD pulley, Gates Green Belt, Larger front HX, Catch Can, Synergy 2 gallon fender tank... to name a few
Old 12-19-2023, 05:17 PM   #3
CalgaryZL1
CalgaryZL1's Avatar
Drives: 2020 Chevy Camaro ZL1
Thats easy...
I was going to suggest cam until I read the part about don’t want to spend extra money.
Old 12-19-2023, 09:55 PM   #4
Bangkok_ZL1
Flying around Thailand
Bangkok_ZL1's Avatar
Drives: 2019 Camaro ZL1
Thanks scott
Oil Pump Replacement..... That's scary
Bangkok_ZL1 is offline   Reply With Quote
Old 12-20-2023, 08:02 AM   #5
Tyrolblue67
Drives: 2019 ZL1 Camaro
Can you explain why you're replacing the oil pump in your 2019?
Preventative maintenance or did the oil pump fail?
Tyrolblue67
Tyrolblue67 is offline   Reply With Quote
Old 12-20-2023, 09:29 AM   #6
SOCAL.M6.ZLE
Thanks scott
Safe to assume you are upgrading to the Katech unit?
Who is doing the work? and at what cost?
Old 12-24-2023, 07:29 AM   #7
Tyrolblue67
Hmm.
A few interesting questions to the op left unanswered.
Tyrolblue67
Old 12-24-2023, 06:42 PM   #8
ZLRob
Super Stock
ZLRob's Avatar
Drives: Chevrolet Camaro ZL1
Mandatory to every build that happens on these engines (none are exempt) is the oil pump itself, DOD delete, LME billet tensioner (the chain is strong and stout in factory form), and appropriate cam needed to accommodate the DOD delete. Anything less is just asking for trouble down the road. Especially if you leave those stupid DOD lifters in.
758 HP/ 804 TQ
