12-19-2023, 05:52 AM | #1 |
Drives: 2023 Chevy Camaro 2LT V6 6MT Join Date: Sep 2023
TPMS not close to being accurate
I’ve checked numerous times with my $100 liquid filled gauge as well as other dry gauges I have. Not only is the reading usually 3-5 lbs off but often shows one tire very low. Lower than the others. Not always the same tire. This is a cold reading. That said, after driving for a half hour or so, the pressures start to read more accurately although still a little high…..around 34 lbs. these are the runflats. Anyone have this issue as well?
2023 Camaro 2LT V6 6MT Vivid Orange Metallic
12-19-2023, 06:54 AM | #2 |
Not to the same extent, but one of my TPMS sensors consistently shows 1-1.5 psi lower when cold, and pressures appear to slowly equalize as the tires warm up.
Now, arguably it could also be the tire and not the sensor, but I won't risk tire shops messing with my precious 1LE wheels more than absolutely necessary, so I'll probably never know...
12-19-2023, 09:06 AM | #3 |
Mine are within 1 psi on a 2017. I have a set of take offs from a 2018, also within 1 psi compared to my digital gauge.
I think these are 315 Mhz sensors. Maybe GM switched suppliers at some point. |
12-19-2023, 09:43 AM | #4 |
Who Needs to KNOW?
I find mine to be very accurate to longacre gauge. I love that it updates *very* fast compared to some others cars i've seen.
ing for grip.
12-19-2023, 11:00 AM | #5 | |
Drives: 2022 1LT RS 2.0t/6spd Join Date: Mar 2022
12-19-2023, 11:25 AM | #6 | |
The sensors are piezoresistive devices and they must incorporate some kind of temperature compensation. The sensors would be sold with an advertised linearity over a certain temperature range. |
12-19-2023, 02:07 PM | #7 |
Drives: 2022 2LT RS Convertible Join Date: Apr 2021
Every month when I get my OnStar report it got 1 tire way off. In the winter I can park the car for 3 months and every report has a tire way off. But put mt air gauge on them and all set at 35psi.
12-19-2023, 08:27 PM | #8 |
This is good info. At least I’m not alone and really it’s not the end of the world. I’ll try checking again when tires are warmed up with the gauge. If it’s fairly close then all good.
12-20-2023, 08:19 AM | #9 | |
Hot Camaro
I have found mine to be fairly close pretty much all of the time although once my car is parked for the winter, I don't do any sort of checks. I would absolutely expect there to be some discrepancy with fairly cold temps since the sensors operate off of a battery and those don't like cold temperatures. I would be headed back to the dealer to have an accuracy check done and get the sensors replaced if they're off. |
12-20-2023, 08:38 AM | #10 |
Drives: '22 LT1 Coupe Join Date: Nov 2021
Living in an area of wide temperature fluctuations, chasing balanced, equal tire pressures is a fool's errand. Otherwise, to achieve it would likely entail multiple daily inflation / deflation activities. For me, it's not that important for daily street driving if pressures are close.
12-20-2023, 01:14 PM | #11 | |
12-26-2023, 10:48 PM | #12 | |
Somewhere in the Kalahari
Drives: 2021/18 (de-fresh) 3LT RS Join Date: Dec 2017
When the tires need air, I park the car in the garage and let the tires cool down from driving. I slightly overfill them by 1-2 psi (adding a factor of +1 psi for each 10 degrees that the current air temperature exceeds the average air temperature forecasted for the time I will start my morning commute). Alternatively, if I am at a shop, I give them the specific front and rear pressures I want using the same rough calculations. Then, on my next commute day, just before I depart, I use my air gauge to blip the valve on each tire, letting out small bursts of air until the tire reaches my target PSI. I use Measurement Ltd digital gauges, model MS-4021b: http://measurement-ltd.com/4021b-det.html No daily/multiple inflation/deflation required! Just close attention to detail about how and when you are setting the tire pressures. Agreed! The TPMS on the 2019 Subaru Outback seems to take forever for the PSI to come up at the start of a drive, and displays "--" until then. The sixth gen starts with what I am guessing is the last reading before the TPMS sensors "went to sleep," and they all come online with current readings shortly after the tires start rolling. Last edited by The Maverick; 12-26-2023 at 11:57 PM. Reason: Added photo - note that I run my fronts 2psi higher than the rears, so the front-rear variation in the photo is intentional. |
12-27-2023, 06:17 AM | #13 |
Good info!
01-03-2024, 08:31 PM | #14 |
I don't trust tpms as much as my $2 tire gauge.
