Old 12-17-2023, 09:46 PM   #1
dbs1
Drives: 2017 ZL1
What pressure do you run in your DR’s?
Been experimenting and 15.5 was certainly too low but 17-18 seemed good for the qtr but had to bump that up to at least 20psi for the 1/2 mile or car wanted to move the back end around too much, Running MT’s 17’s.
dbs1 is offline   Reply With Quote
Old 12-17-2023, 09:48 PM   #2
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Originally Posted by dbs1 View Post
Been experimenting and 15.5 was certainly too low but 17-18 seemed good for the qtr but had to bump that up to at least 20psi for the 1/2 mile or car wanted to move the back end around too much, Running MT’s.
Not sure what size DRs you’re running, but I ended up having to air up my 325/50/15. Got way too loose at the top end in the 16-17 pound range, now I run 20-21.
Old 12-18-2023, 07:56 AM   #3
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
drag radials generally like to be in the 20-23psi range. You are down in bias ply slicks territory.
Old 12-18-2023, 08:49 AM   #4
2018ZL1
2018ZL1's Avatar
Drives: 2018 ZL1 A10 NFG 2019 COPO 350 SC
I run 16.5lbs in my Hoosier drag bracket radials, these are 17 inch 28-10.5 tire.
The 15 inch I just installed I am gonna try and start higher and see how it goes, 18-19?
The higher the better, as long as it hooks of course.
2019 COPO #32
350 SC
8.25 167MPH
2018 ZL1-NFG-A10
388CI L8T
9.32 147MPH
2018ZL1 is offline   Reply With Quote
Old 12-18-2023, 09:29 AM   #5
ZL1Atlanta
ZL1Atlanta's Avatar
Drives: 2017 Chevrolet Camaro ZL1
21 cold is where I start the day and adjust up or down based on conditions.
2017 ZL1 - PB 7.85 @ 175 MPH @ 3682 lbs @ 1313 DA (work in progress)
Built by Vengeance Racing, tuned by Elite Tuned
ZL1Atlanta is offline   Reply With Quote
Old 12-19-2023, 10:25 PM   #6
dbs1
Drives: 2017 ZL1
Thanks for the input guys!
Old 12-20-2023, 08:03 AM   #7
Sillysspeed
Drives: 22 LT1
Generally the heavier the car the higher pressure needed. The better the surface the more pressure you can run. I run 17-17.5 psi in my racecar which is 3000lbs. I run 19-20psi in my 6th gen. Run a touch less if it’s a not so great surface.
Sillysspeed is offline   Reply With Quote
