Old 12-17-2023, 11:05 AM   #1
Tim M
Tim M's Avatar
Drives: 2018 Camaro SS 1LE
Extrude Hone OEM Manifolds
Anyone try extrude honing the OEM exhaust manifolds?
I'd like to stay with the OEM setup due to visual/emission restrictions and realize the manifolds and likely more so, the inlets to the cats are my next limiting factor. Amazing the engine makes 650 HP thru that tiny openning especially on the driverside...
Extrude honing used to be advertised a good bit, but don't hear about it much now.
I realize a set of tubular headers is the optimum answer...
Thanks.
Tim M is offline   Reply With Quote
Old 12-17-2023, 11:14 AM   #2
Z OH 6
Drives: 2024 CT5-V Blackwing
No one uses this anymore. I think it would be a waste of money on exhaust manifolds.
Old 12-17-2023, 02:33 PM   #3
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Agreed. If you have to stay with the manifolds, finding a way to open up the collector and primary cat opening is the key. Believe @swisstyphoon has some info on doing this previously.
Old 12-17-2023, 03:51 PM   #4
khcoaching
khcoaching's Avatar
Drives: 2021 1SS 1LE
SPD makes them for the Coyote F150 and they are pretty darn good. Quite a few people got fed up with false knock codes and these offer performance very close to headers, while maintaining OEM type fitment.
Dyno test on Whipple F150 -
https://youtu.be/QywHE9T0DW0?si=NtpAOz-vrDUHxtzE
khcoaching is offline   Reply With Quote
Old 01-18-2024, 01:54 PM   #5
Tim M
Tim M's Avatar
Appreciate the replies. I came across a hand porting service:
https://socalporting.com/
They do Camaro manifolds as well...$400 which seems reasonable for the hand porting it requires. I do agree the cat entry's appear to be a significant choke point which this doesn't address.
Old 01-18-2024, 02:57 PM   #6
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
These are mostly tubular, except the flanges, so there isn't much to extrude. I'd listen to Josh' and check out that post from swisstyphoon. If I recall - he ported the cat' flanges, mounted the manifolds to fixtures, and replaced the squashed pipes with larger-round pipes. I'll be looking into this some day, too.
'20 ZL1 Black "Fury"
