Old 12-17-2023, 10:37 AM   #1
Nataphen
Drives: None
Katech high flow HPFP
I don’t think I’ve seen anyone talking about this thing yet. Are there any details out there other than what’s on the website so far?
https://katechengines.com/i-30498270...fuel-pump.html
Nataphen is offline   Reply With Quote
Old 12-17-2023, 10:54 AM   #2
IndyZrider
IndyZrider's Avatar
Drives: 21 SHOCK ZL1 M6
saw them talking about it at PRI in indy....supposed to the cats meow...iirc it takes care of the low side too....
IndyZrider is offline   Reply With Quote
Old 12-17-2023, 10:59 AM   #3
Nataphen
Drives: None
The low side is handled by their new drop in dual pump setup. Just waiting on their PnP harness and filter to run that piece fully through the factory controls.
Old 12-17-2023, 11:04 AM   #4
IndyZrider
IndyZrider's Avatar
yup...youre correct....i mixed them up....
Old 12-17-2023, 11:28 AM   #5
JSH
JSH's Avatar
Drives: '20 ZLE
Wonder how its specs compare to LPE's BBFP?
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 12-17-2023, 12:38 PM   #6
swisstyphoon
Former GM Technician
swisstyphoon's Avatar
Drives: 2018 ZL1 A10, 06 Silverado Duramax
There is already a thread with more info about this hpfp on the forced induction section.
https://www.camaro6.com/forums/showthread.php?t=621637
2018 Camaro ZL1 A10
Rotofab Big Gulp, Nick Williams 103, Magnuson 2650, 9.17" (14%) lower, 90mm upper, Vengeance Racing Heads (LME) Cam Package (Cammotion Stage 1), Johnson Lifters, DSX dual intank pump, Lingenfelter high flow check valve, Motion Raceworks Flex Fuel adapter, LPE Big Bore Hpfp, XDI 30% Injectors, BBK shorty headers, Custom 2.75" down pipes, Gesi Gen2 high flow cats, MM catch can.
2006 Silverado Duramax Diesel
MPI Compound Turbo
40% over Injectors
Efi Live DSP5 Tuning
Follow me on Instagram: SwissZL1
swisstyphoon is offline   Reply With Quote
Old 12-17-2023, 06:56 PM   #7
Nataphen
Drives: None
Thank you. Subbed to that one.
Old 12-17-2023, 07:20 PM   #8
Megahurtz
Snackbar Tuning
Megahurtz's Avatar
Drives: 2023 SGM ZL1
Katech responded to me on Instagram. They basically expect it to flow more than the LPE BB. However, is that because its designed to run at higher pressures? People run the LPE at 2900 in LT4's. I want to know if the Katech will flow more at 2900 psi vs the LPE. I'm going to buy one and test it.
Old 12-17-2023, 07:28 PM   #9
Sillysspeed
Drives: 22 LT1
That’s the million dollar question.
Sillysspeed is offline   Reply With Quote
Old 12-17-2023, 08:52 PM   #10
XXX ZL1
XXX ZL1's Avatar
Drives: 2024 ZL1 M6
Good to see Katech getting involved in these cars and the fueling limitations.
2024 Riverside Blue ZL1 M6
Magnuson 2650R, NW 103, Roto Fab Big Gulp
Kooks 2 inch LT's, Stainless Works Legend NPP
THP Billet Valve Covers, Mighty Mouse Wild CC
Signature Forged 20x10.5/20x11.5, BMR springs,
BMR Cradle lockout, AAD Billet arms
2023 Vivid Orange ZL1 M6 - sold
2019 Riverside Blue ZL1 A10 - sold
XXX ZL1 is offline   Reply With Quote
Old 12-18-2023, 07:54 AM   #11
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
My hunch is that it's slightly better. If you go back to 2017 or so LPE made 1400hp on E85 with their fuel system on a turbo LTx. This was done on an engine dyno similar to Katechs testing. The problem is belt driven superchargers consume a lot of power to turn. A 2650 probably takes 100hp to spin at 18psi. So a couple ricer math equations later this pump is probably good for 1050whp on full E85 with +65 injectors and a 38% cam fuel lobe along with a good low side to feed the top end.
Old 12-18-2023, 09:09 AM   #12
Sillysspeed
Drives: 22 LT1
I think a lot of the big power guys have already went port injection and they aren’t coming back. Imo if this pump can provide a legit gain to the bolt on guys who want to take it a step further to run full e85 or stretch it further on E blend it will be a hit. Yes it would appeal to the guys with aftermarket cam also but I think the bolt on guys will be the biggest market
Old 12-18-2023, 09:39 AM   #13
Megahurtz
Snackbar Tuning
Megahurtz's Avatar
I agree. There are some people who don't want crazy street cars but they have the financial ability to pay for expensive parts to stay away from more complicated setups or meth.
My interest in the Katech is strictly if it can flow more than the LPE BB on the stock LT4 cam lobe at the same pressures. If it does then this will be a huge win for the stock cam bolt on guys that want to run full pump E. Then the next win will be for the real radical builds that are pushing the limits over 1200rwhp.
Old 12-18-2023, 11:08 AM   #14
KingLT1
KingLT1's Avatar
Yeah I also fall in that category. And like you I have been playing with bigger injectors and fuel pumps on bolt-on cars extensively for the last 4-5yrs. The problem I see with LT1 cars is the pump lobe is even smaller than the LT4. These high side pumps really need a bigger fuel lobe to get the most out of them. So it might make more sense if wanting to stay on the conservative side but NEED more fuel is to grab the BTR big fuel lobe(32%) stock profile cam. IF you can do the work yourself it would cost less than half of one of these big pumps and likely provide more fuel headroom vs a stock lobe cam with bigger pump. Or keep your LPE and do the BTR big fuel since you already have it.
