![]() Drives: 2018 ZL1 1LE Join Date: May 2022
Kooks Headers + Corsa Catback Fitment Question
Hey all!
Recently I picked up a pair of Kooks 1 7/8" longtube headers with the high flow catted connection pipes for my ZL1. A deal popped up on a Corsa Xtreme+ catback system that I could not pass up and will be picking it up soon. I'm planning on having the whole system installed along with a Rotofab Big Gulp intake and an LT5 throttle body sometime in March or April (whenever the weather allows in UT). My question is: has anybody had any experience mating the Corsa X pipe to the Kooks connection pipes? I have heard some mixed results ranging from cutting/welding being necessary, to the Corsa X pipe being able to mate right up with the connection pipes. To clarify, I will link the headers and Corsa catback exhaust I'm using below: Headers:https://wildhammermotorsports.com/16...n-pipes-kooks/ Corsa Exhaust:https://www.lethalperformance.com/co...hoCPhQQAvD_BwE Also, if anybody has any miscellaneous info pertinent to installing headers/exhaust, please let me know! I have already spoken to my tuner about disabling the rear O2s to ensure that the dreaded P0420 and P0430 PDTCs are NOT triggered (I was under the assumption that this was basically impossible to do now based on the HPTuners 5.x release, but allegedly it is still possible, and it is even possible to roll back to version 4.x)! Is there anything else that I should know about to ensure smooth installation? Thanks all! Last edited by SammYyYyY; 12-11-2023 at 03:20 AM. |
![]() ![]() ![]() ![]() Drives: 2023 ZL1 Join Date: Dec 2022
My long tube headers and exhaust post starts here.
https://www.camaro6.com/forums/showt...=611982&page=5 My install deleted the secondary CATs, but the headers have a bung for the secondary O2 sensors to be installed, so the secondary CATs are gone but not the secondary O2 sensors.
Katech Track Day CAM 38%•BTR Dual Valve Springs•Johnson Lifters•Trend 3/8 Chromoly Pushrods• VVT Del•CNC Heads•AFM Delete• C5-R Timing Chain•Katech Oil Pump•Katech 112mm•Maggie 2650 3.25” Upper/ATI SD w/10.32” +20%•10 Rib Belt•RFBG•FI IC Stage 2•THPSI Port w/875cc Inj•Katech Dual Fuel Pump•DSX Aux Pump•SW 2" Headers w/Legend NPP•GESI UHO 4.5" CATs•Brisk RR14S Plugs•BMR Motor Mounts•BMR Cradle Lockout &Bushings Kit•BMR Rear Suspension & 15" Conversion•DSS 1pc DS•RPM 6-Point Roll Cage•10lb FireSense+ w/4Fire SFI 17.1 Fire Sys•Weld Forged Vitesse Rear 17x10 Beadlocks-Front 18x6•Unlocked TCM
#3 | |
![]() Do you live in a state that requires all emissions monitors to be "Ready" to pass? In UT it is allowed to have 1 monitor read "Not Ready" and still pass, meaning everybody around here just disables the rear O2s so they don't have to worry about catalyst efficiency. |
#4 | |
Same vibe around here; only certain counties in Utah do emissions. Unfortunately, I reside in one of the 3 counties that does require it. Thankfully, even though we have them, they aren't too stringent. Like I said, one monitor can read "not ready" and still pass. People have actually had success passing around here with disabled rear O2 sensors and hollowed out cats, since there is no sniffer test, and technically that passes both the plug-in test and the visual test.
#6 | |
![]() Drives: 2020 Camaro ZL1 1LE Satin Steel Join Date: Feb 2023
That is a heck of a deal on the corsa extreme. I bought mine a few months ago and paid $2940 after taxes.
#7 |
Good deal for sure ! I think that's a little less than I paid for mine a 10 months ago from CSP Racing! I still have my original Corsa Xtreme with NNP (actuators valves not included) Axle back for sale. They are boxed up and ready to ship. They guy that was originally buying them back out. No problem. I'm firm on $1800. I'm re-listing them in the market place soon.
#8 |
I actually didn’t snag them brand new from that link, I just used that as a reference for the set that I bought; I actually found mine used for $800 for the whole set 😊
