![]() Drives: 2016 Camaro SS Join Date: Sep 2023
Wire to nowhere
Just bought 2016 camaro recently entry and noticed this wire that is cut near engine compartment fuse box. It comes from the back of the engine, not sure if it’s part of the AFR gauge or not. Attached video of this wire, any ideas?
https://youtube.com/shorts/JWcf1sjhc...52P2JzLEE2DGWi Last edited by rjgss; 12-10-2023 at 07:20 PM. |
You might want to double-check your post, there is no video attached. It's probably easier on everyone involved if you upload the video to youtube or a similar public location.
That might be the signal wire for the flex fuel sensor. After watching it a few times, that is what it is.
https://www.bing.com/ck/a?!&&p=43dbe...NDY5OTUx&ntb=1 |
Aha, yeah, that's the extra flex fuel sensor wire that is now removed from the connector, just as dmcmahan60 said.
So that wire is not needed unless I want to run E85? Is it supposed to plug into fuse box?
It’s going to tuner next week, guess I can ask them |
It is in the instruction I posted
#7 |
![]() ![]() ![]() Drives: Garnet Red - 20 ZLE Join Date: Jun 2016
Flex fuel signal wire, I would take up the lead coming out of the fuse box but other than that, no need to worry. Better yet, hook it back up so you can run E85
