Old 12-10-2023, 12:00 PM   #1
DaveC113
DaveC113's Avatar
Drives: 2018 Camaro 1SS 1LE
How To Fit 18 x 12" Square
When I got my first wheel/tire setup for CAMC autox I went with a ZLE sized staggered setup because I believed 18x12s wouldn't fit up front on my SS 1LE, and at the time the Falken 660s in 315/19 and 305/19 were the hot tire. Now I'm running 295/35/18 RE71RS, on 18x12 they are definitely faster. Here's how I fit this setup on my car:
-Obtain a set of 18x12 et41 wheels, Apex offers a few choices.
-Install Vorshlag camber plates with the plates at the maximum camber setting and then adjust the camber to ~3.5 degrees at the strut. This will give you a bit more clearance than maxing out camber at the strut and then adjusting at the plates.
- You'll need the right spacers and studs. I got some inexpensive Titan brand 1.5" hub-centric spacers and hammered out the studs that came with them. If you have magride, you may or may not want to add a 3-5mm spacer as well, it will reduce how much you need to grind the strut. MSI studs are for Mustang GT, PN 10.0067, 97mm length. Also, use MSI lug nuts. The MSI studs fit in the holes the original studs in the Titan spacers were in without modification. It's a somewhat tight fit but that's a good thing.
https://www.titanwheelaccessories.co...studs-set-of-4
https://www.msirp.com/
- Grind the strut so you have a few mm of clearance or get aftermarket coilovers. If getting coilovers for a magride car, obtain a suspension module from a car WITHOUT magride so you don't throw error codes or have to use those stupid magride delete kits.
I have an SS 1LE, so it has magride, I'm installing MCS coilovers this winter but, but here's a pic of the install with the OEM magride struts. It requires a decent amount of grinding but not much different than an 18x11 with a 1" spacer that's commonly done.
Old 12-10-2023, 12:16 PM   #2
Christian1LE
Drives: 2004 BMW 330CI, 2022 1SS 1LE
One thing you want to keep in mind is that even though the wheel clears your tires might still rub on the actual strut if the spacing between them is not far enough. Mine was rubbing a little bit on 18x11 with 315 hoosiers. Probably not an issue with 295's. And it only rubs on the track when the tires are working, in the garage there is some space between the tire/strut.
Christian1LE is offline   Reply With Quote
Old 12-10-2023, 01:47 PM   #3
DaveC113
DaveC113's Avatar
Yeah, so with 12s you're less likely to hit the strut and more likely to hit the fender as there's more wheel toward the outside and a tire will be less pinched.
I have a friend who has run 335/30/18 BFGs on this setup with coilovers, but this depends on firmer than stock suspension to avoid rubbing on the fenders. My 295 setup is VERY close to the front fenders but so far so good... no rubbing on the strut or fender.
As with everything YMMV, I make no guarantees. It works for me though, and I posted this as I rarely see folks going 18x12, perhaps because, like me, they listened to other folks who said it wasn't possible. It IS possible, and it's a faster setup than 11s up front in my case.
Old 12-19-2023, 10:34 AM   #4
Clam
Clam's Avatar
Drives: 2017 Camaro 1SS
Agreed! I had 18x12 +6 wheels fitted in the front to clear the coilover, but added a 3 mm spacer so that the 315 tire clears too.
Clam is offline   Reply With Quote
Old 12-19-2023, 11:33 AM   #5
DaveC113
DaveC113's Avatar
Yup, that's close. With an 18x12 et 41 and the 1.5" spacer it comes out to et3, which is what you ended up with after adding the 3mm spacer.
Old 12-19-2023, 01:54 PM   #6
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
335/30/18 jesus lol let me guess he has mcs coilovers also?
Old 11-13-2024, 12:07 PM   #7
carguy55
carguy55's Avatar
Drives: 2018 1SS 1LE
I need to get to 18x12" for these 315 tires. 11" works but I think they would be much happier on 12s, especially the A7s. I've done the strut mod, camber plates and MCS coilovers so my 18x11s fit great with a 7mm to make them near flush with the fender. But this is not a square setup which would be ideal.
Mods: MSD, Headers, 95mm TB, high flow cats, full 3" exhaust, SPL, MCS 2-way remotes, sway bars, rear diff lock outs, Sparco racing seats, 6 point harness, CMS roll bar, Nine lives wing, 6" splitter, ACS canards.
www.youtube.com/@Racer_Mike87
Old 11-13-2024, 02:45 PM   #8
DaveC113
DaveC113's Avatar
I'm very happy with the 18x12 setup. My results this year were excellent, probably better than I deserve for how good of a driver I am.
I also installed MCS 2-way remote coilovers which made a huge improvement, so that's part of it too.
Apex Black Friday sale is close, best time to buy wheels...
Old 11-14-2024, 11:57 PM   #9
VaporPressure
Drives: '18 ZL1 1LE
Are there any downsides to running a 1.5" spacer in front? Safe for road course use? I'm considering trying to fit 12" wheels on ZLE (DSSV) suspension. My understanding is that it's safe, but it still seems a little disconcerting.
VaporPressure is offline   Reply With Quote
Old 11-15-2024, 07:43 AM   #10
Msquared
Msquared's Avatar
Drives: Chevrolet SS 1LE
It's completely safe as long as you have enough stud length to capture adequate threads with the lug nut, and you make sure the spacer is flat on the hub face and wheel and that the wheels seats all the way down on the spacer's face (i.e. make sure the wheel's center bore fits over the spacer's hub pilot if equipped).
Matt Miller
2020 SS 1LE
Msquared is offline   Reply With Quote
Old 11-15-2024, 09:33 AM   #11
VaporPressure
Drives: '18 ZL1 1LE
ok thanks Matt
