Old 12-06-2023, 08:49 PM   #1
Dmoney2SS
Drives: 2022 summit white Chevy Camaro 2SS
Which air intakes fit 95mm tb?
I purchased a 95mm LT5 throttle body and was wondering which air intake I would need to get to be able to install this as the stock intake boot isn’t big enough to go over the 95mm
Dmoney2SS is offline   Reply With Quote
Old 12-07-2023, 07:37 AM   #2
6spdhyperblue
Drives: 2SS 1LE
I thought the stock one fit. You gotta work it
Old 12-07-2023, 12:18 PM   #3
Dmoney2SS
When I installed the tb the intake tube seemed to be just a hair too small
Old 12-07-2023, 01:01 PM   #4
Mark114
Mark114's Avatar
Drives: 2016 2SS Convertible
I had to heat the air intake tube with a hot air gun and stretch it to fit. I used a softball and some wood shims to stretch it before installing it on the TB.
Old 12-07-2023, 01:04 PM   #5
RideWithDanger
RideWithDanger's Avatar
Drives: 23 2SS 1LE
The stock one will fit but Rotofab pairs very well with a 95mm TB. Just make sure you get a tune.
Instagram: RideWithDanger
Current Mods: Rotofab, Ported LT2 intake, LT5 TB, Kooks Headers, AWE Touring Catback
Radiant Red 23' 2SS 1LE
1100: 11/14/22 | BUILT: 3/16/23
2000: 2/17/23 | 4200: 5/8/23
3000: 2/27/23 | 5000/6000: 5/15/23
RideWithDanger is offline   Reply With Quote
Old 12-07-2023, 11:41 PM   #6
Dmoney2SS
Are you still running the stock air intake? What other mods do you have?
Old 12-08-2023, 12:17 AM   #7
Mark114
Mark114's Avatar
My 2SS is running the GM CAI. It should be the same size as the stock air intake. The car is also running an LT2 intake manifold and a flex fuel kit.
Old 12-08-2023, 09:40 AM   #8
Dmoney2SS
Yes I plan on getting a tune after I install headers also
