Old 11-30-2023, 11:41 AM   #1
FireMission
Drives: 2016 SS
How to Clear Tune and Reset Car to Factory Settings
Got a used 2016 ss. Dealer said it had an HP Tune on it. I'd like to clear the tune and reset the vehicle back to factory settings. How do I do that?
FireMission is offline   Reply With Quote
Old 11-30-2023, 12:23 PM   #2
JANNETTYRACING
JANNETTYRACING's Avatar
With a j2534 tool and a subscription to AC delco TDS.
www.jannettyracing.com
email tedj@jannettyracing.com
Old 11-30-2023, 12:57 PM   #3
Mark114
Mark114's Avatar
Drives: 2016 2SS Convertible
Does the engine have any modifications (e85 flex fuel, cam, headers, etc.) that would require the modified tune?
Old 11-30-2023, 01:33 PM   #4
FireMission
Drives: 2016 SS
It's got headers and x pipe installed.
Old 12-02-2023, 09:15 AM   #5
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Then you don't want to flash the tune back to stock unless you put factory headers back on it.
Old 02-15-2024, 01:56 AM   #6
ZL1C7
ZL1C7's Avatar
Drives: 2023 SS 1LE 10SPD
Adding to Kings comment, If you flash it to stock with headers your will generate 420/430 cat codes at a minimum and then eventually some more. These codes will get stuck in ECU and will not clear (unless you flash it again with factory GM software) Ultimately, if you flash it to stock, the car needs to be stock unless you have something that won't affect the tune like a cat back or air filter upgrade,
ZL1C7 is offline   Reply With Quote
