Old 11-24-2023, 01:45 AM   #1
Dvs510
Dvs510's Avatar
Drives: 2018 Camaro SS/1LE
BEWARE!!!!
My FBO 2018 1LE was stolen a week ago.. no luck getting it back and insurance is paying out.. after asking around and research I found out there’s 2 specific ways they are stealing the cars now and takes them 2 minutes.. I hadn’t heard of either one until it was too late. Hopefully this will prevent 1 of u from the pain I’m dealing with.. first way is there doing “relay attacks” (u can search YouTube videos for that).. but basicaly they have a high power antenna and get close to your front door where most have there keys, the antenna picks up the key signal and relays it to a reciever that someone else in your car has and it tricks the car into thinking your keys r in it and they can start it and drive off. So don’t leave your keys by your front door and put them either in foil or in a metal can to help block the signal… the second way is also total bullsht and gm is at fault.. anyways, they can use your vin number and using a laptop and a program from gm they can look up your key specifics and clone a key in less then 2 minutes and litteraly have there own key. Seen a ring camera video of them doing this to a ctsv.. litteraly 2 minutes and they had the car and driving away.. so covering the vin number in the windshield would b a good start.. as soon as I get another 1LE tho I will be doing kill switches and also hiding apple air tags in the car to help track it… onstar was useless in my case. They disconnected that immediately.. anyways, hope this helps save someone’s car
2018 SS/1LE... summit white.. E85 ,Ported LT2 IM, Roto Fab, soler performance ported throttle body, secondary delete, mbrp axle back, tuned by CCNC
Dvs510 is offline   Reply With Quote
Old 11-24-2023, 08:36 AM   #2
Boost Creep
Boost Creep's Avatar
Drives: '18 1SS 1LE
Originally Posted by MSS1LE View Post
Sorry about your car. I heard San Francisco has a ton of problems.
Auto or manual?
Same here.
Good luck.
'18 1SS 1LE Black, PDR
Old 11-24-2023, 08:48 AM   #3
m6-lt1
m6-lt1's Avatar
Drives: 2023 Chevrolet Camaro 2SS 1LE
Sorry about your car. I heard San Francisco had a problem with car thefts.
Auto or manual?
All SS 1le’s before 2021 are manual.
Current: 2023 2SS 1LE
Prior:
2016 Camaro 1SS
2007 Mustang GT
2008 Civic Si
m6-lt1 is offline   Reply With Quote
Old 11-24-2023, 09:13 AM   #4
Odabo
Odabo's Avatar
Drives: 2023 2SS 1LE
So, here's a question; How does one cover the VIN? Mine is not accessible as far as I can tell.
2023 2SS 1LE Radiant Red, A10, PDR, Black Lugs, ACS Rock Guards, ACS ZL1 1LE Side Skirts
Odabo is offline   Reply With Quote
Old 11-24-2023, 03:09 PM   #5
Christian1LE
Drives: 2004 BMW 330CI, 2022 1SS 1LE
I think the best solution if you're worried is to install a kill switch that takes power away from the fuel pump. That's what I would use if I was in a big city and had to park my car somewhere dangerous.
Christian1LE is offline   Reply With Quote
Old 11-24-2023, 04:02 PM   #6
Dvs510
Dvs510's Avatar
The vin number in the windshield that u can see from outside the car
Old 11-24-2023, 04:04 PM   #7
Dvs510
Dvs510's Avatar
It was right I know front of my house… but yea, my next car I’ll be running both a fuel pump kill switch and a starter kill switch
Old 11-24-2023, 04:17 PM   #8
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Attached is a pic of the kill switch that I have.
Old 11-24-2023, 05:14 PM   #9
m6-lt1
m6-lt1's Avatar
LOL you'd have way bigger problems if you shot at a thief unless you live in Texas. I've read all about this situation and what can happen if we were to "take matters into our own hands" and unless you can afford an amazing lawyer it's best not to go that route.
Prior:
2016 Camaro 1SS
2007 Mustang GT
2008 Civic Si
Old 11-24-2023, 05:29 PM   #10
Joshinator99
Moderator
I thought the sarcasm was obvious, sorry. Just a play on his “kill switch” term.
Old 11-24-2023, 05:50 PM   #11
m6-lt1
m6-lt1's Avatar
Ah gotcha. Now I feel like I should have caught that haha.
Prior:
2016 Camaro 1SS
2007 Mustang GT
2008 Civic Si
Old 11-24-2023, 06:40 PM   #12
Joshinator99
Moderator
But I will say, if a potential car thief even remotely thinks you’re packing, they’re probably going to try their luck elsewhere.
Old 11-24-2023, 08:34 PM   #13
Dvs510
Dvs510's Avatar
I’m actualy glad I didn’t catch them in the act, otherwise I’d be dealing with way worse crap right now…. And also, the video I saw of the friends wife’s ctsv that got stolen… 2 guys were runnin the laptop and in the car and the other 2 guys u can see standing guard w pistols in hand
Old 11-24-2023, 09:20 PM   #14
Joshinator99
Moderator
Until law enforcement steps up and handles this stuff, it’s a bad situation all around. Thankfully you’re fine and cars can get replaced…still sucks lol…!
