![]() Drives: 2017 Camaro 1LT Join Date: Sep 2018
Transmission fluid change interval
After the tranmission shudder fix with the Mobil 1 blue labeled fluid, i've been changing the fluid every year (But i imagine this is an overkill) including filter and pan gasket.
What would be a recommended change interval for the A8? Thanks |
![]() ![]() Drives: 2017 Camaro SS, 2011 Corvette GS Join Date: Feb 2019
Every year is a bit much. Won't hurt anything except your wallet.
I would say at minimum 25K miles between intervals. Max 50K. The main killer of trans fluid is heat. But from what I have seen on my 2SS, my trans fluid doesn't even approach getting hot, even on long drives or spirited drives. |
| Tags |
| change, flush, interval, transmision |
