![]() Drives: 19' SW ZLE Join Date: Jun 2022
Was hoping to hop in here and get some advice and input from you all on here.
Story: Was driving home yesterday when a truck hauling limestone rocks from some site ended up dropping a large rock off the back and I was going about 20mph without enough time to react out of the way... There was a loud scraping sound under the car from the front to about mid way tranny area before the car cleared the rock like Titanic hitting an iceberg. Car was fine until I got home about 10 min later and the check engine light came on. Took it to O'Reileys and it pulled a; "P015D: Delayed Response Lean to Rich Bank 2 Sensor 1" Came home, put the car up on the race ramps to take a look. Some decent uncarriage damage to the front skid plate. The real issue I guess is the damage to the CAT. You can see scratches and minor dent on where the rock was hitting. There is also what appears to be a small space that water is dripping out of the heat sheild by the CAT. Not sure if this is normal or not. Observation: 1. I don't see any ripped wires from O2 sensors 2. I don't see any punctures in the CAT or anywhere So what could be causing this? Car runs fine, just not sure if the CAT is dead now or if I'm missing some damaged wiring somewhere. I have attached pictures of the affected areas of concern. ANY and all help is greatly appreciated in advance! Just want to get it fixed asap. Thanks! ![]() ![]() ![]()
Summit White 2019 Camaro ZL1 1LE
- Rotofab Big Gulp - CSP LTs Past: - 02' SS Procharged (stolen) - 01' Z28 (sold) |
![]() ![]() ![]() ![]() ![]() Drives: 2020 Chevy Camaro ZL1 Join Date: Apr 2023
First off stop tailgating! A 20 mph reaction in a Camaro is nothing. Secondly said object interacted with your O2 sensor
#3 | |
The O2 still looks intact though. I don’t see any wires impacted. Bank 2 sensor 1 is drivers side correct?
Yes
They are a lot like a spark plug, sensitive. They may not look damaged, but they are damaged. I would change it out.
Fair enough will do. Appreciate the input!
#7 | |
![]() Drives: 2024 ZL1 Join Date: Apr 2023
#8 | |
![]() Drives: 2023 SS 1LE Sharkskin Join Date: Jun 2023
This right here. Demand that they pay for the damages. These trucking companies often like to say they are not responsible for rock damage. That's true only if the rock/debris was already on the road. But if it comes from their load they are 100% responsible for that. I'll bet that's over $1K in damages.
ΜΟΛΩΝ ΛΑΒΕ
#9 |
Lover of Speed
Drives: 2018 ZLE Join Date: Feb 2016
I thought Bank 2 sensor 1 would be passenger side, front O2 (the one before the primary cat). I could be wrong though.
I am dealing with the same code but Bank 1 Sensor 1 (P015B) and there are a bunch of things that can cause that code unfortunately. I am thinking my cats are done since I run 15-50 full time.
Killer Whale Racing
2021 One Lap of America Track Videos 2019 One Lap of America Track Videos 2017 One Lap of America Track Videos 2022 Ram TRX 2018 Camaro ZL1 1LE 2020 Range Rover Sport SVR (Sold) 2014 Grand Cherokee SRT (Sold) 2014 Camaro Z/28 (Sold) |
#10 | |
![]() Drives: 2024 ZL1 M6, 1978 Beechcraft Baron Join Date: Jun 2018
#11 |
USCG Retired (MKC)
Drives: 2018 2SS 1LE Black Join Date: Aug 2018
[QUOTE=Og Neon;11382226]I thought Bank 2 sensor 1 would be passenger side, front O2 (the one before the primary cat). I could be wrong though.
And you would be correct. To the OP, I would clear the code and see if it reoccurs before I tossed money at it. |
#12 |
![]() ![]() Drives: 2017 Camaro SS, 2011 Corvette GS Join Date: Feb 2019
I would also recommend checking all of your exhaust connections starting at the exhaust manifolds.
Looks like some very hard hits and there could now be a leak at any of the connections. Check for bends and re-torque all of the bolts. A simple exhaust leak could be what is causing the O2 code. Our cars are extremely sensitive to exhaust leaks. BTW, you are very lucky. When I had a 2013 BMW 335XI (nice car), I was active on the Bimmer forums. A member there ran over a large piece of concrete just like you did. It caused so much damage to the underneath of the car, it was enough to total out the car. |
#13 |
I think you may have a leak upstream of the primary o2 sensor or at the bung. You are getting a delayed response on lean to rich. For example, going from cruise to accel the car will enrichen the mixture. The o2 sensor should see that enrichment immediately.
As far as debris off the truck, and flying debris in general, I have always been advised to say the debris hit my car before it ever hit the road. Once it hits the road, it is no longer flying debris. |
#14 | |||
[QUOTE=Warrior102;11382247]
Good to know on the debris too. I'm going to contact the company hauling this crap in my neighborhood and see what comes of that. I will also be investing in a dash cam 100% now...
