Old 11-22-2023, 12:46 PM   #1
Ajs16400
Drives: 2017 Camaro SS Convertible
LT4 Supercharger on LT1 getting codes.
Vehicle runs great and drives amazing I could not be any happier how the car drivers.
The issue I am having is a Check Engine Light. I am getting a p0121 "Throttle Position Sensor 1 Performance" and a p1101 "Intake Air Flow System Performance"
I am running a Soler Performance 95MM throttle body. I have talked to Soler and they believe it's a tuning issue and my tuner believes it's a throttle body issue.
Has anyone run into this issue, does anyone know the best place to start to get this figured out as the light is just bugging me?
Ajs16400 is offline   Reply With Quote
Old 11-22-2023, 03:11 PM   #2
NiickySaz
NiickySaz's Avatar
Drives: 2023 Camaro 1LT V6
Stupid question. Is the Throttle body that you have specific for the LT4 or LT1?
The only reason I ask is because I see they offer for BOTH engines. If the ECM is pulling info from a LT1 spec but getting LT4 communication I can see that being an issue.
NiickySaz is offline   Reply With Quote
Old 11-22-2023, 03:34 PM   #3
CalgaryZL1
CalgaryZL1's Avatar
Drives: 2020 Chevy Camaro ZL1
Another factor is what air intake are you running?
Old 11-22-2023, 03:38 PM   #4
Ajs16400
Roto Fab
Old 11-22-2023, 03:44 PM   #5
CalgaryZL1
CalgaryZL1's Avatar
I would work backwards put your stock throttlebody on and tune for that, see if you get any codes. Rule out a bad part.
Old 11-22-2023, 05:52 PM   #6
NiickySaz
NiickySaz's Avatar
Maybe the MAF?
