Old 11-21-2023, 09:25 AM   #1
FlukeSS
FlukeSS's Avatar
Drives: 2020 Camaro 2SS A10
Update on my blown engine
So apparently, as many expected I spun a rod bearing and blew up the crankshaft (cracked)
Good news is the engine block is salvageable.
Old 11-21-2023, 09:32 AM   #2
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
Whooopsy
Is cracked crank part of a spun bearing, to be expected? Or is that why it spun?
Old 11-21-2023, 09:40 AM   #3
FlukeSS
FlukeSS's Avatar
More good news: They estimate $8500 to rebuild the engine, and another $4000 for a Stage II Cam, DOD delete and e85 tune
So I am within my budget to get the car fixed and an upgrade.
Old 11-21-2023, 09:41 AM   #4
FlukeSS
FlukeSS's Avatar
Originally Posted by WhiteMale View Post
Whooopsy
Honestly, they aren't to sure, and was wondering what the tune looked like. Chad with CBI, was surprised the crank cracked as the power I am pushing is just not in the area of worry for that to happen. But like anything in life, sometimes shit just happens.
Not sure if a rear spun rod bearing would cause the crank to crack, or if the crank cracked and caused the rear spun rod bearing.
He said it doesn't look like oil or pressure was an issue. He said the oil pump looked good. Just for some reason that rear bearing got hot.
Old 11-21-2023, 09:51 AM   #5
Junction65
Junction65's Avatar
Drives: 2011 GMC Sierra 1500
Went back and read through your original thread on the failure event. Hate that it happened and glad to see you have the resources/budget to do the repairs/upgrade.
2023 LT1 Coupe M6 - Black (GBA) on Black (H1T)
Blade spoiler (5ZU), Recaro seats (AQJ), Technology pack (Y3W)
LT1 PBC engine built by Shane Parker
Current mileage: 372
Junction65 is offline   Reply With Quote
Old 11-21-2023, 09:53 AM   #6
laynlo15
Drives: 2022 Lt1 A10
Glad to hear he's getting you taken care of, best in the Midwest in my opinion and that's why I referred him to you.
I broke the crank in my 2016 on the Forged Engine, it broke internally and proceeded to char every bearing in the engine. When I pulled the balancer bolt oil ran out of the front of the crankshaft, not supposed to do that, Right? It sure isn't but that's modding, crazy shit happens. Sure glad your going to save some money to do some extra modding. Keep us up to date.
Old 11-21-2023, 09:54 AM   #7
FlukeSS
FlukeSS's Avatar
I have high anxiety right now lol. Be nice to be able to drive my car again, been without it since beginning of June.
Old 11-21-2023, 09:57 AM   #8
FlukeSS
FlukeSS's Avatar
Appreciate the referral. I like Chad, good guy, and down to earth. He even stayed late because he knew I was driving to drop off the car when he didn't have to, but I greatly appreciated that he did.
Old 11-21-2023, 10:06 AM   #9
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
C’mon man! I thought extra lubrication was a good thing?!?
Old 11-21-2023, 10:11 AM   #10
SomeGeoffGuy
SomeGeoffGuy's Avatar
Drives: 2023 2SS Convertible
At least you are going to be down over winter and not really miss driving it. I think I have driven mine twice this month.
-Geoff
'16 2SS Convertible - White on white, mag-ride, NPP, nav. Sold!
'23 2SS Convertible -Same as above except orange.
SomeGeoffGuy is offline   Reply With Quote
Old 11-21-2023, 10:26 AM   #11
18.2SS.1LE
18.2SS.1LE's Avatar
Drives: Chevrolet Camaro
What mods did you have?
A 416 short block is near $8,000... something to think about instead of rebuilding that one.
Procharger P1X, CSP Big Boy Cam, CSP Headers, LT5 Throttle Body, MSD Intake, LT4 HPFP, LT4 Injectors, JMS BAP, 93 + Boostane - 750+WHP
18.2SS.1LE is offline   Reply With Quote
Old 11-21-2023, 10:34 AM   #12
FlukeSS
FlukeSS's Avatar
K&N CAI
2" Speed Engineering LT (cat delete)
3" Speed Engineering X-Pipe (cat delete)
MBRP 3" Axle back (getting rid of the suit case finally)
DIY E85 flex fuel
Stage 3 ported LT2 Intake
95mm ZR1 TB
My budget is limited to about $14,000 and I'm not sure if any of the previous mods can transfer to a 416, otherwise I would agree. I think a 416 would use different heads if I am not mistaken in which case more cost with a 416. And because of the Stage 2 Cam they are going to put in: I also need a T87A unlock kit to have the trans tuned for better cam synergy.
Old 11-21-2023, 11:01 AM   #13
18.2SS.1LE
18.2SS.1LE's Avatar
Heads should be the same, but a limiting factor without porting them.
Old 11-21-2023, 11:22 AM   #14
fj5gtx
fj5gtx's Avatar
Drives: 70 GTX, 06 Mustang, 22 Camaro LT1
$9400 Holley Crate 6.2 an option?
https://www.holley.com/products/engi...SABEgLpK_D_BwE
2022 CAMARO LT1 COUPE AT10
fj5gtx is offline   Reply With Quote
