Old 11-18-2023, 03:35 PM   #1
Spartant2112
Drives: Camaro ZL1
ZL1 A10 Burnout Issue
I'm trying to do a burnout at the track. I'll push traction control twice and go into race mode, but the car will rev out to 3k and bounce between 3k and 2k and backfire a lot. I don't know if I'm not turning of TC correctly or maybe if the previous owner had something installed cause it almost sounds like it's two stepping. Is this normal? My tires won't even spin.
Spartant2112 is offline   Reply With Quote
Old 11-18-2023, 03:48 PM   #2
JamesNoBrakes
JamesNoBrakes's Avatar
Drives: 2SS 1LE
Hold the TC button till both of the lights come on.
2018 2SS 1LE
2023 Colorado ZR2
2022 Stinger GT-line AWD
JamesNoBrakes is offline   Reply With Quote
Old 11-18-2023, 04:15 PM   #3
split_bumper
Drives: 24 ZL1, 6.2L Denali, 73 SplitBumper
That almost sounds like its trying to put you in launch mode? I don't have an A10 but doesn't that, if turned on, activate from brake and gas at the same time?
2024 ZL1 Radiant Red / Coupe / M6 / PDR / BCD / Carbon Scoop, Dash, Shifter / Red Seat Belts / Black Lugs
https://cws.gm.com/vs-cws/vehshop/v2...FJ1R60R0111531
split_bumper is offline   Reply With Quote
Old 11-18-2023, 06:17 PM   #4
JSH
JSH's Avatar
Drives: '20 ZLE
Hold down the off button by the shifter until TC off shows on gauge panel. Burnout in manual. Start tires spinning in 1st and shift to 2nd before taking it up to 5-6k
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 11-18-2023, 06:19 PM   #5
Booher
Booher's Avatar
Drives: 2019 zl1 6 speed
I had the same issue, I believe it's because you are in race mode and it has its own traction mode maybe? When I reviewed my pdr, traction control was popping up after I put it in race mode. Maybe try regular mode and hold the traction button to turn off.
Old 11-18-2023, 08:49 PM   #6
Vigilante375
Drives: 2018 Camaro ZL1
You need to hold the TC button down for at least 5 seconds. Give the link below a once over and familiarize yourself with the cars traction management.
https://www.camaro6.com/forums/showthread.php?t=496996
Old 11-19-2023, 06:40 AM   #7
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
you can use line lock which is a PITA...watch the video
https://youtu.be/6S9lLI8vw3M?si=wtsaDJ_5hetj5I24
