Old 11-12-2023, 06:14 PM   #1
SwL_Wildcat
SwL_Wildcat's Avatar
Drives: 2024 ZL1
2024 ZL1 1LE VINs
For your viewing pleasure.
Here is something that may interest a few folks here. 2024 ZL1 1LE cars. *New designates it was found this week.
Riptide Blue
https://cws.gm.com/vs-cws/vehshop/v2...FK1R66R0118139
https://cws.gm.com/vs-cws/vehshop/v2...FJ1R68R0118128
https://cws.gm.com/vs-cws/vehshop/v2...FJ1R67R0117326
https://cws.gm.com/vs-cws/vehshop/v2...FK1R67R0118120
https://cws.gm.com/vs-cws/vehshop/v2...FK1R69R0118104
https://cws.gm.com/vs-cws/vehshop/v2...FK1R60R0117892
https://cws.gm.com/vs-cws/vehshop/v2...FK1R65R0118617
https://cws.gm.com/vs-cws/vehshop/v2...FJ1R66R0118872
https://cws.gm.com/vs-cws/vehshop/v2...FK1R62R0118798
https://cws.gm.com/vs-cws/vehshop/v2...FJ1R67R0118816
Sharkskin
https://cws.gm.com/vs-cws/vehshop/v2...FK1R63R0117322
https://cws.gm.com/vs-cws/vehshop/v2...FK1R64R0117457
https://cws.gm.com/vs-cws/vehshop/v2...FK1R6XR0117317
https://cws.gm.com/vs-cws/vehshop/v2...FK1R63R0118938
https://cws.gm.com/vs-cws/vehshop/v2...FK1R68R0118773
https://cws.gm.com/vs-cws/vehshop/v2...FK1R68R0118949
https://cws.gm.com/vs-cws/vehshop/v2...FJ1R67R0119206
White
https://cws.gm.com/vs-cws/vehshop/v2...FK1R62R0117425
https://cws.gm.com/vs-cws/vehshop/v2...FK1R64R0118110
https://cws.gm.com/vs-cws/vehshop/v2...FK1R66R0117749
https://cws.gm.com/vs-cws/vehshop/v2...FK1R68R0117431
https://cws.gm.com/vs-cws/vehshop/v2...FK1R68R0118675
Radiant Red
https://cws.gm.com/vs-cws/vehshop/v2...FK1R65R0117449
https://cws.gm.com/vs-cws/vehshop/v2...FK1R60R0118637
Red Hot
https://cws.gm.com/vs-cws/vehshop/v2...FK1R65R0117984
https://cws.gm.com/vs-cws/vehshop/v2...FJ1R69R0118333
Orange
https://cws.gm.com/vs-cws/vehshop/v2...FK1R63R0118454
Yellow
https://cws.gm.com/vs-cws/vehshop/v2...FK1R67R0117579
https://cws.gm.com/vs-cws/vehshop/v2...FK1R63R0117790
Black
https://cws.gm.com/vs-cws/vehshop/v2...FK1R60R0118072
https://cws.gm.com/vs-cws/vehshop/v2...FK1R69R0117535
https://cws.gm.com/vs-cws/vehshop/v2...FJ1R65R0117440
https://cws.gm.com/vs-cws/vehshop/v2...FJ1R63R0118134
https://cws.gm.com/vs-cws/vehshop/v2...FK1R6XR0118631
https://cws.gm.com/vs-cws/vehshop/v2...FJ1R67R0118153
https://cws.gm.com/vs-cws/vehshop/v2...FK1R64R0119693
https://cws.gm.com/vs-cws/vehshop/v2...FK1R64R0119676
https://cws.gm.com/vs-cws/vehshop/v2...FJ1R64R0119373
https://cws.gm.com/vs-cws/vehshop/v2...FK1R64R0119838 *New
Ontario Canada got 2 in black
https://cws.gm.com/vs-cws/vehshop/v2...FK1R64R0117636
https://cws.gm.com/vs-cws/vehshop/v2...FK1R6XR0117706
Quebec
https://cws.gm.com/vs-cws/vehshop/v2...FJ1R64R0117333
Then there is the 2 that went to GM.
https://cws.gm.com/vs-cws/vehshop/v2...FJ1R61R0100022 (1st one made)
https://cws.gm.com/vs-cws/vehshop/v2...FJ1R6XR0100097
SwL_Wildcat is offline   Reply With Quote
Old 11-12-2023, 08:44 PM   #2
LateBrakeU2
Drives: 15 RH Z/28, 23LT1VOM
No VOM, Hendrick got a few go figure.
LateBrakeU2 is offline   Reply With Quote
Old 11-13-2023, 03:51 AM   #3
SwL_Wildcat
Drives: 2024 ZL1
When Radiator does another 2024 pass I'll look for more. Except for the 2 GM owned cars these are all high VIN numbers, probably made in the last 2 weeks. For those that really want a 2024 ZL1 1LE at least they can call the dealers on the stickers and try to get one.
Old 11-14-2023, 11:23 PM   #4
Camfab
Drives: ‘23 ZL1-1LE
Thank you, how did you find these? I’ve been looking at the Chevy locator and ZLE didn’t even show up.
Camfab is offline   Reply With Quote
Old 11-15-2023, 07:28 AM   #5
SwL_Wildcat
Drives: 2024 ZL1
I took Radiator's data of all 2024 VIN's and searched for the A1Z trim code on all ZL1's which is the 1LE package. Gearhead said there were allocations so I was curious if any had been built yet, turns out a few have been. With 3 weeks of production left I'm curious if they make any more, if not they will be a super rare car.
Old 11-15-2023, 10:42 PM   #6
Camfab
Drives: ‘23 ZL1-1LE
I guess I’m missing something, where are you searching? Who is Radiator, and how did he get all the VIN’s?
Anyway thanks for the info…..
Old 11-16-2023, 12:03 AM   #7
Bumbleboy92
Long hauler
Bumbleboy92's Avatar
Drives: 2022 Camaro 2SS 1LE
It sort of started at this thread.
While searching for ZL1 Collectors Edition cars to complete the list, we realized we could utilize the URL GM has setup to display window stickers for 2020+ cars. I made a crude script and supplied some VINs to the list but raidator has created a better and more complex script that pulls way more information for each VIN.
Essentially the URL pulls a window sticker PDF. That PDF has all RPO codes and information found on these .xlsx files. I’ve mostly stopped using my script as raidator’s is immensely faster and more accurate but SwL_Wildcat has generously created these .xlsx files with the input of raidator’s data from his script.
Started as a Collector’s Edition search and now they’ve grown it to a much broader and better audience
The crude basic idea is as follows:
https://cws.gm.com/vs-cws/vehshop/v2...wsticker?vin=X
Replace the X with a GM VIN.
Download/read the PDF if returned, you now have all the variables to store.
Append variables to .csv file
The fun time is iterating through every VIN starting at sequence 0 to whatever number that model year would end at which you’d only find once it stops finding VINs.
2016 1LT v6
- Totaled
Happiness: Infinite
Old 11-16-2023, 08:01 AM   #8
SwL_Wildcat
Drives: 2024 ZL1
There is 1 VOM now in Ohio. 7 new ones this week.
Old 11-16-2023, 11:16 AM   #9
Camfab
Drives: ‘23 ZL1-1LE
Wow, that’s really cool, thanks for the detailed explanation!
Old 11-16-2023, 09:33 PM   #10
raidator
raidator's Avatar
Drives: 24 2SS CE M6 convertible
yeah, who is *RADIATOR"??
I know some guy that goes by RAIDATOR (aka half raider, half predator)
raidator is offline   Reply With Quote
Old 11-16-2023, 10:17 PM   #11
Bumbleboy92
Long hauler
You know how many times autocorrect tries to change you to radiator? I need to add your username to the dictionary
2016 1LT v6
- Totaled
Happiness: Infinite
Old 11-17-2023, 05:29 AM   #12
Sorange
Sorange's Avatar
Drives: 2018 ZL1 1LE
I have a friend that works at the plant. They texted me on Nov 6 and told me they were going down the line. I don't think any of the cars here are going to be list for sale. A friend of mine is getting a Nitro Yellow ZLE and from what his dealer said, GM selected the dealers, and they called their top list customers and asked if they wanted the allocation. That's how it work out for him.
Sorange is offline   Reply With Quote
Old 11-17-2023, 07:05 AM   #13
SwL_Wildcat
Drives: 2024 ZL1
Sorry. I type in "raidator" and it changes it to "radiator" on my phone automatically. If it do it on the PC it just highlights it in red telling me it doesn't recognize the word. I will endeavour to do better.
Old 11-17-2023, 06:15 PM   #14
In this sorry world of autocorrect and phone screens, you're looking at a perpetual uphill battle, brother.
By the way, my name autocorrects to "airpod", which, needless to say, resulted in a bunch of funny moments.
