Old 11-11-2023, 09:53 AM   #1
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
Pulling to the right
Have an issues with the car pulling to the right. Spent hours working with a great shop in Clifton and we ran out of time. Front suspension is completely stock. Rear is all BMR non-adjustable except for the toe rods (Adjustable BMR). It is minor but usually the car is perfect usually so its on my fix it list.
Something is causing the wheel to turn slightly right, when you hold the wheel straight the car goes straight. Camber, caster, toe, etc you name it is spot on. Had it on and off the rack many times and it stays repeats
Had the car in the air and nothing was loose/sloppy when you grabbed a wheel. Checked brakes, there isn't one dragging. Swapped front tires, didn't change a thing.
I'm left with rear tires (Nitto 555R2) swapping/replacement (they are low). This issue didn't just happen so maybe low rears has an impact?
Any other thoughts?
Old 11-11-2023, 11:42 AM   #2
The only reason I've ever had the wheel pulled away from center was tires. How about swapping the rears left to right and checking if the pull inverts? Easiest way to identify or rule out the rear tires.
Old 11-11-2023, 11:46 AM   #3
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
Yeah, that was my plan next. I actually need new rears so it might be the plan for next year.
Old 11-11-2023, 12:19 PM   #4
ZLRob
Super Stock
ZLRob's Avatar
Drives: Chevrolet Camaro ZL1
That is exactly what I would do. It sounds like one of his tires has radial separation and truthfully, it wouldn't surprise me if it did. Nitto has somewhat of a history of not being the best with the QA/QC of their new tires.
Then again that's what happens with mass production so I can't say it's on them entirely.
2017 Red Hot ZL1 A10 - Apex ARC-8's, 305/ 325 PS4's, DSX 9.06 12% lower, Griptec 2.5 upper, NGK HR7 Ruthenium plugs, Nostrum 22+ injectors, XDI Goliath HPFP, Katech dual in tank low side pump, Katech oil pump, LME tensioner, DOD delete, LT1 big fuel cam, Jokerz ported blower, MPI lid, GMS hood extractor bracket, Soler ported 87mm (91mm eff) TB, Granatelli SS plug wires, Cordes LTR reservoir, DMS T-stat housing, 186* LS3 T-stat, Black Widow Angry Housewife/ Corsa NPP mufflers, Borla X pipe, BMR engine mounts, Banks iDash, Lithium Battery, AEM X- Series, HP Tuners, E85, 16.5 psi
834 HP/ 840 TQ
Old 11-11-2023, 12:32 PM   #5
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
Road force balancing might find a tire problem.
Old 11-11-2023, 12:37 PM   #6
Supercharged!
Drives: 2023 Camaro ZL1
Could also be the roads you are testing on... I'm sure you thought of that though
Supercharged! is offline   Reply With Quote
Old 11-11-2023, 12:41 PM   #7
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
All good answers.
Old 11-11-2023, 05:12 PM   #8
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
Yes, we obviously didn't test it on anything with a crown.
Old 11-12-2023, 05:47 PM   #9
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
I've got 345/30R19 Nitto 555RII on there now with 305/30R19 PS4S on the front. PS4S don't come in 345 but 355/30R19, OMG are they expensive! ($719 each)
