Old 11-10-2023, 06:59 PM   #1
Jonathan91
Drives: 2022 Camaro 1ss 1le
Throttle body spikes
had the car cammed for about two weeks had it tuned by gpi. All was going good until I changed my slicks for my stocks 1le. Took it for a drive and it started with this problem. The throttle body % goes crazy up to 60% while I’m just cruising. Can’t seem to upload a file but I’m about 15-20% throttle and it spikes everywhere up to 60%. I just replaced the throttle body and nothing. I was reading that it could be the pedal sensor
Jonathan91 is offline   Reply With Quote
Old 11-11-2023, 10:56 PM   #2
Jonathan91
Anyone? Here are some screenshots since I can’t upload my log file
Old 11-12-2023, 07:17 AM   #3
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Did you send your data logs to GPI…? Where they tuned it you should give them first crack at fixing it.
Old 11-12-2023, 02:32 PM   #4
Jonathan91
Yea but won’t be till Monday till they get back at me. It’s like if I’m revving at other cars trying to race
Old 11-12-2023, 07:14 PM   #5
Joshinator99
Moderator
Had a similar problem when I tried to run a Soler ported 103/107mm throttle body. Car was possessed. Tuner told me to ditch the ported TB ASAP. Went to a Katech 112mm one and problem was gone.
Old 11-12-2023, 08:11 PM   #6
Jonathan91
All I have is stock tb, and roto fab, lt2 intake, btr stage 1 and headers. It was driving fine until a morning all of a sudden you think the car wants more air and a bigger tb?
Old 11-13-2023, 06:07 PM   #7
Jonathan91
So gpi told me the tune was perfect they suspect a chafed wire or something came loose
Old 11-13-2023, 07:04 PM   #8
Joshinator99
Moderator
They could be right. How long did you drive it with the tune and no issues?
Old 11-13-2023, 09:57 PM   #9
Jonathan91
I drove about 200miles with the first startup tune drove it from the shop to my house then around town. Then one night I swapped my slick for my 1le stocks and flashed the second revision gpi sent me after they said everything looks good on the logs. Took it out for a spin and this problem occurred. I sent them a log of the problem and he said he couldn’t see what the problem was on the log I sent. he sent me a file with drivers demand back to stock but same problem still happens. I seen my drivers side o2 extension got melted from touching the headers so I’ll be replacing that one with an extra extension and will be replacing both o2 sensors this week I also got a new foot pedal
Old 11-14-2023, 06:38 AM   #10
Joshinator99
Moderator
Yeah melted wires will raise havoc for sure. Probably best to go over it all carefully and then try again with everything repaired.
Old 11-14-2023, 11:59 AM   #11
6spdhyperblue
Drives: 2SS 1LE
What about the harness next to the passenger header
Old 11-14-2023, 12:14 PM   #12
Joshinator99
Moderator
Great point!
Old 11-14-2023, 12:40 PM   #13
Megahurtz
Snackbar Tuning
Megahurtz's Avatar
Drives: 2023 SGM ZL1
Compare the two files from GPI and see what changed. I know there is a table that references gear selection that can cause erratic throttle behaviors. If there is nothing obvious that stands out in the compare files, then you have a mechanical or electrical issue not related to the tune.
Could also flash the original file back and see if the issue persists.
Old 11-14-2023, 04:34 PM   #14
Jonathan91
Haven’t check the passenger side yet. If I flash to original tune like the stock file will it still be able to drive around just to check if the problem still happens?
