![]() Drives: 2022 camaro SS 1LE Join Date: Jan 2023
Wire question
Ok so just wanna hear from someone smarter than I when it comes to wires. I have 3 sets that i can use all custom wires and all seem really well made.
First set is a custom set of Taylor thundervolt wires these are the thinnest with respect to jacket. But they have fiberglass sleeves on them as well. When ohmed they come up at 26 ohms when tested. Second set is a pair that were made by Scott they have a thick fiberglass sheath as well as fiberglass sock as well. These ohmed at 21 ohms when tested. Third set is the new ones i just got they are made with Moroso Ultra 40 race 8.63 wire. They have similar thick fiberglass jacket like the scotts but they dont use a sock since they have these awesome 2000 degree ceramic boots by the headers. But they ohm at 31 average. Car is a fbo with H/C/I makes over 560 wheel and just wanting to know which yould use and why. Im leaning towards the ceramic boot ultra 40s since one of the best wires made. But dont know if it having the highest ohms ill be leaving anything on the table by not using the Scotts since they have the lowest. Thoughts thanks |
#2 | |
Moderator
Thats fair safly the three i have are all the best taylor, moroso, and scott. I will be using the moroso mainly because they have ceramic boots and that provides probably the highest resistance to heat and damage. Its also has the same thickest wire and same outside fiberglass 10mm jacket. It doesnt have a sock like the other 2 but with the ceramic boots i feel its still superior. Thanks for the response.
![]() ![]() ![]() ![]() ![]() Drives: 19' ZL1 A10, w/pdr Join Date: Sep 2014
Granitelli wires are 0 ohms, that's what I run.
Moderator
![]() Drives: 18 Camaro 2SS Join Date: Jul 2022
Plug Wires
I run MSD wires on both of my Camaro's with zero problems. If your interested here's the part number I used.
33829 |
