Old 11-05-2023, 07:41 PM   #1
dpevans
Drives: 2024 Riverside Blue 2SS 1LE
jack points on the 1LE
traded up to a 24 SS1LE from a 2016 RS. I purchase the jack pads like i had on my 16 and put them on yesterday and realized the 1LE has additional support bracing under the car with lift points. When you guys lift your cars do you use the cross bracing points or stick with the pinch points with jack pads.
dpevans is offline   Reply With Quote
Old 11-05-2023, 09:03 PM   #2
MatthewAMEL
MatthewAMEL's Avatar
Pinch welds with the zl1addons lift points installed.
2017 HBM SS 1LE
Sold
2023 Wave Metallic
CT5-V Blackwing M6
2025 Hysteria Purple
C8 Z07
Old 11-05-2023, 09:24 PM   #3
Those are not lift/jack points, they are for the chassis transporter in the factory, only to be used while the drivetrain is not yet mated to the unibody. They won't be able to support the weight of the whole car (well, one corner at a time, but they can still cave in). Use the pinch welds at the 4 (+2) official lift points.
Old 11-07-2023, 06:22 AM   #4
dpevans
Good to know, thanks,
Old 11-08-2023, 08:05 AM   #5
CamaroDreams76
Tri-County Camaro SWFL
CamaroDreams76's Avatar
Drives: 2013 IOM 2SS/RS/1LE
Pinch weld with the jack pad
CamaroDreams76 is offline   Reply With Quote
Old 11-08-2023, 04:15 PM   #6
302crossram
302crossram's Avatar
Drives: 2023 Sharkskin 2SS
I have 2 floor jacks and start with the front simultaneously,
(ZL1 addons jack pads)
then jack the rear using a hockey Puck in the jack.
I lift the rear in the center of the beefy brace above the rear diff.
safe, strong place to lift the rear IMO..... ymmv
Old 11-25-2023, 03:36 PM   #7
Camby
Camby's Avatar
Drives: 2023/2SS/1LE/RadiantRed/A10
I lift the passenger side up on the 2nd pinch weld of 3 locations (under the door hinge) before putting two stands down under pinch welds 1 and 3. Then do the same on the drivers side. The second pinch weld spot will lift one side of the car up evenly.
Oh and use these:
Jack Pad
https://a.co/d/burpxUB
Pinch Welds Protector
https://a.co/d/dMdIwaQ
2023/2SS/1LE/Radiant-Red/A10/Sunroof/Copper-Free-Breaks/Navigation —— Order History: 6/17/22-1100, 3/7/23-3000, TPW-4/3/23, 4/4/23-3800, 4/8/23-Delivered
Camby is offline   Reply With Quote
