Old 11-05-2023, 02:42 PM   #1
lt4camaro
lt4camaro's Avatar
Drives: 2021 LT1 10 speed auto
E85 sensor kit removal question
I am removing my E85 sensor kit that I installed, am returning the car to stock status. Will I have any CEL issues ? do I have to deactivate the E85 tables? I had Jannetty activate and set up the car for E85 originally after I successfully installed and wired the E85 sensor kit.
lt4camaro is offline   Reply With Quote
Old 11-05-2023, 04:48 PM   #2
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Depends if flex fuel diagnostics is enabled.
Old 11-05-2023, 05:48 PM   #3
lt4camaro
lt4camaro's Avatar
Thanks King, but not sure what you mean. Are you saying when Jannetty enabled E85 and tuned the car on E85 and enabled flex fuel diagnostics, I will have issues and flex fuel diagnostics will have to be disabled?
Old 11-05-2023, 06:51 PM   #4
Megahurtz
Snackbar Tuning
Megahurtz's Avatar
Drives: 2023 SGM ZL1
That is exactly what he is saying
Old 11-06-2023, 07:48 AM   #5
lt4camaro
lt4camaro's Avatar
Thank you.
Old 11-06-2023, 10:58 AM   #6
Megahurtz
Snackbar Tuning
Megahurtz's Avatar
The problem with removing the Flex Fuel sensor on a car where it was tuned in, is if the diagnostics are enabled(and maybe even if they are not), you will get a CEL for FF sensor failure. Then the ECU will lock in on a default ethanol content as part of the failure strategy. I think the OEM value is 40% Ethanol. So if you pull the flex fuel sensor and put 93 octane in, the ECU will treat it like E40 and run super rich.
The tune needs to be removed. I would think most tuners would flash the stock file back in for free in your situation. At least I would.
Old 11-06-2023, 11:04 AM   #7
lt4camaro
lt4camaro's Avatar
Well thank you for that, it certainly puts that into a perspective I can understand.
