Old 10-28-2023, 02:42 PM   #1
CamaroChill
CamaroChill's Avatar
Drives: Camaro 2016 RS
Lightbulb Installing new side marker lights, but not working
Hi there, I'm a new Camaro owner and today I was replacing the side markers lights. I bought some on Amazon.
The right part works like a charm but when I installed the front-left side marker, it's not turning on at all. Tried other lights and still doesn't work.
I am a total beginner with this, so how do I know where the problem is if the light is not turning on? Does it mean a fuse is out? Where do I check?
Thanks!
CamaroChill is offline   Reply With Quote
Old 10-28-2023, 02:52 PM   #2
SwL_Wildcat
SwL_Wildcat's Avatar
Drives: 2024 ZL1
What bulbs are in there? Are they polarity sensitive? Is it possible to pull the bulb, turn it 180 degrees and put it back in?
SwL_Wildcat is offline   Reply With Quote
Old 10-28-2023, 06:03 PM   #3
CamaroChill
Yes but the ones I bought on Amazon fit in the place of the bulb. The other side markers I installed work just fine after pulling the bulb and plugging them in.
Similar to these:
How do I find out where the issue is?
Old 10-28-2023, 06:06 PM   #4
CalgaryZL1
CalgaryZL1's Avatar
Drives: 2020 Chevy Camaro ZL1
Similar to these:
I went through this already, if you’re updating them with LED just go buy diode dynamics and get it over with. You buy them five times off Amazon to get one good set or buy them once from diode
Old 10-28-2023, 07:04 PM   #5
SwL_Wildcat
Drives: 2024 ZL1
Similar to these:
Can you reverse the plug in? I know on the 3157 LED bulbs I have put in my truck if you plug them in 1 way they don't work, but if you plug them in the other way they work just fine.
Old 10-28-2023, 07:34 PM   #6
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
[QUOTE=CalgaryZL1;11373898]I went through this already, if you’re updating them with LED just go buy diode dynamics and get it over with. You buy them five times off Amazon to get one good set or buy them once from diode[/QUOTE
Gotta add a +1 to diode dynamics. I have only had good experience with them.
Also really like the color choice on your car OP!
Ventmaster is offline   Reply With Quote
Old 10-28-2023, 07:36 PM   #7
Hey CamaroChill, try the suggestion above, LEDs are polarity sensitive (being diodes, they only conduct electricity in one direction), and especially cheaper parts don't have built-in electronics to reverse the wrong polarity for you automatically. Very easy to try, just plug it in the other way.
If this doesn't fix the issue, try swapping the bulbs side to side to see if it's the bulb or the car. If it's the car, try putting the stock bulb back in to see if the LED part blew a fuse.
If the stock bulb still works, you have a problem with the product; furthermore, if the LED bulb works on one side but not the other, toss it in the garbage and buy Diode Dynamics or Oracle or something reputable instead. (For the record, I bought this unit from JW Motorsports in May 2019 after repeated issues with Diode Dynamics, and all four of my JWM side markers have been working flawlessly since then. Rumor has it that Diode Dynamics have since then fixed the problems with their suppliers and later units do not die like mine did several times.)
The fuses to check for side marker operation are F18 (body control module 4) and F28 (body control module 3) in the underhood fuse box.
Old 10-28-2023, 07:51 PM   #8
scott_0
scott_0's Avatar
Drives: 2018 Hyper Blue Metallic SS 1le
agreed, Amazon stuff is very hit and miss...
scott_0 is offline   Reply With Quote
Old 10-28-2023, 08:33 PM   #9
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
I agree, I've had the Diode Dynamics Smoked Markers for nearly 4 years and they work and look great...
Old 10-28-2023, 10:43 PM   #10
CamaroChill
Thanks everybody for the suggestions.
I will definitely check the other side and possibly buy the Diode (I’m not in US otherwise I would’ve gotten them already).
The stock bulb wasn’t working as well for the front left part. And as I said, I’m a total beginner in this, does it mean that the fuse is burnt? Is it easy to replace the fuse or do I need a mechanic? If anybody could give me indication on which fuse to buy and how to replace it, and check if it’s broken, I’d really appreciate.
I love this community of Camaro lovers!
Old 10-28-2023, 11:57 PM   #11
Possibly, you need to check the underhood fuse box. I posted a picture above that I marked up the fuses in.
The good news is that you will find both a fuse puller (looks like small plastic pincers) as well as a row of spare fuses in the fuse box, in positions F68 to F72. See if the ones I indicated are blown, which you can tell by pulling the fuse, looking through it and seeing a burnt or at least no longer continuous metal line within. If that's what happened, pick a spare fuse that has the same amperage (also color). For the record and to help your future purchase, our cars use Micro2 ATR fuses.
With that said, if the LED bulb burnt out a fuse, it's defective, so replacing the fuse and plugging the thing back in will just result in another burnt fuse, I would put the stock bulb back in, and if it works, buy a better side marker.
If these fuses are intact, check the connector and the wiring on the side that doesn't work now.
Old 10-29-2023, 08:54 AM   #12
CamaroChill
Thanks a lot for the kind explanation, I’m glad it also has spare fuses.
When you said that our cars use Micro2 ATR fuses, does it mean I cannot buy one of those kits on Amazon that contains 100+ mini and medium fuses because they are not compatible?
Should I look specifically for “Micro2 ATR” fuses when buying spare fuses?
Last question for now, I've seen the diagram that you shared but if the fuse for the side markers lights is out, shouldn't they all stop working? In my case, it's only the front-left and maybe the rear-left lights.
Thanks again for the time.
Old 10-29-2023, 09:24 AM   #13
CalgaryZL1
CalgaryZL1's Avatar
Here are the specs for micro2 atr and yes, Amazon will sell them
Old 10-29-2023, 10:23 AM   #14
CamaroChill
I’m here working on the car and the fuses in F18 and F28 look good, I even tried replacing them but the front left side marker light still doesn’t turn on unfortunately
