Old 10-26-2023, 01:13 PM   #1
ZapperZ
Drives: 2018 ZL1 1LE 2022 GMC AT4 HD
Aftermarket Starter
2018 ZL1 1LE here
Has anyone replaced the starter with an after market starter
such as Tilton Part Number: TIL-54-40011 ?
Spoke to Tilton tech and they said they only know that this particular starter fits LT4 but they didn't designate a fit for the Camaro
Has anyone replaced with a performance starter not including reman?
ZapperZ is offline   Reply With Quote
Old 10-26-2023, 01:19 PM   #2
Katech_Mike
Drives: 2015 Camaro ZL1
Are you having specific issues that you are trying to resolve?
The factory Gen 5 LT starter is a very stout piece.
Katech_Mike is offline   Reply With Quote
Old 10-26-2023, 01:20 PM   #3
CalgaryZL1
CalgaryZL1's Avatar
Drives: 2020 Chevy Camaro ZL1
Is the starter dead or is it a grounding problem?
Old 10-27-2023, 03:46 PM   #4
ZapperZ
Slow start getting worse which takes a few tries before starting
H-6 AGM battery new
Installed heavy ground wire
Starter relay on order , rotated same relays in the mean time
Starter has a DEI rap on it
I've read others replaced the starter cable with luck
Probably replace the starter with an OEM and look at replacing
the starter cable
