Old 10-21-2023, 01:28 PM   #1
CalgaryZL1
CalgaryZL1's Avatar
Drives: 2020 Chevy Camaro ZL1
ZL1 tire wear
I just put the car up on the lift for winter storage and noticed the wear pattern on all four outer edges is less than half the tread depth than the inner at 2.25mm compared to 4.95mm on the inner. Sorry no tire depth gauge, had to use my calliper. Can someone please chime in on what this indicates so I have a bit of knowledge for when I go for wheel alignment come spring. First picture is front. Not sure if Eagle F1-3 are designed with gradient tread depth or not? Seems odd All four tires are wearing the same.
Old 10-21-2023, 01:33 PM   #2
FH-ZL1
FH-ZL1's Avatar
Drives: 2021 ZL1
Following, as mine look exactly the same.
FH-ZL1 is offline   Reply With Quote
Old 10-21-2023, 09:55 PM   #3
cdb95z28
cdb95z28's Avatar
Did you check the depth at the dimples or between the tread blocks? The dimples at the edge tread blocks are for checking the depth. If you checked the outer depth between the outer block and the next row of blocks then that is not the correct place to gauge the depth.
Also, If you run the corners hard with the conservative factory alignment (camber) then the outer tread blocks will wear at a faster rate than the inner blocks. Keep your cold tire pressures at 32 or even slightly higher. I’d say if the car drives nice and straight and the steering wheel is centered when driving in a straight line, you’re good. While these cars demand alignment perfection, if all four are wearing consistently and the car is driving great, the alignment is probably good.
Us guys who track our Camaros with these Goodyear 3s will run them clear down to the cords. They are fast throughout their lifespan. On the way to that point, that first tread channel between the outer block and the next one will completely go away. If you drive in wet conditions this obviously won’t be a good choice as the wet performance degrades quickly as these tires wear.
"KEEP THE FAITH"-Fbodfather
Old 10-21-2023, 09:58 PM   #4
cdb95z28
cdb95z28's Avatar
Check at dimples at circles
Old 10-22-2023, 06:17 AM   #5
CalgaryZL1
CalgaryZL1's Avatar
Thanks for the info!
Old 10-22-2023, 10:16 AM   #6
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
Too a factor of Camber. I think your tires look as i expect them too.
Old 10-22-2023, 04:42 PM   #7
SnakeEyeSS
SnakeEyeSS's Avatar
Drives: Camaro 2SS & ZL1
Dimples look like a roadworthy cheat to get around tread depth requirements?
2017 Camaro 2SS A8 Bright Yellow NPP MRC
2023 Camaro ZL1 A10 Radiant Red
SnakeEyeSS is offline   Reply With Quote
Old 10-22-2023, 06:34 PM   #8
FarmerFran
FarmerFran's Avatar
Well, it works
<Insert Cars You Own Here>
Old 10-25-2023, 10:28 PM   #9
ZR1-OK
Drives: 22 ZL1 23 1SS Redline
My alignment was off from the factory. I went to get the rear backup sensor chip fitted and they took care of it under warranty.
ZR1-OK is offline   Reply With Quote
Old 10-26-2023, 09:45 AM   #10
AZ_1LE
Drives: 2019 ZL1 1LE
The outter most blocks of tread and their tread depth are a little misleading. Goodyear put a lot of meat out there for track duty. You can wear them down to they're basically a slick on that area of the tire, but there's still plenty of life left. It's the wear indicators you have to judge it by.
Old: 2017 SS 1LE
Old: 2017 ZL1
Current: 2019 ZL1 1LE
AZ_1LE is offline   Reply With Quote
