Old 10-20-2023, 07:29 PM   #1
Kerry
Drives: 2019 2SS Camaro
Kerry is offline   Reply With Quote
Old 10-20-2023, 07:46 PM   #2
Dynamical
Dynamical's Avatar
Drives: 2022 Camaro LT1 A10
Absolutely hilarious
I'm in the northeast and there's not enough E85 stations to make it work for me. There's a couple shops up here who know how to run it and never had a problem. I'll be going meth in the future
2022 Camaro LT1 A10 - Drag Pack/Corsa double X pipe/AWE track axleback -11.849@118.67MPH/1.798 60'
Dynamical is offline   Reply With Quote
Old 10-20-2023, 10:38 PM   #3
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
Am I missing a picture or something here?
Mods being installed-
Old 10-21-2023, 01:01 AM   #4
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
You and me both, I'm lost on the post...
Old 10-21-2023, 08:40 AM   #5
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Then you will be building another motor?
Old 10-21-2023, 08:42 AM   #6
JANNETTYRACING
JANNETTYRACING's Avatar
I have experience with Meth injection dating all the way back to 1980, Yes I am that old and been doing it that long.
I know how to make it work, but it will never change the reliability or potential engine failures when relying on it as a fuel source.
It has it's place in the performance world but you should know all the details before committing.
Keep in mind when someone is trying to sell you something they have something to gain, so they will tell you all the positives and none of the negatives.
I prefer to educate my customers and let them make the decision knowing full well the risk.
Once they have all the details they rather not mess with it.
I am giving up a sale in the process of educating my customers.
So I have something to lose in the short term but a customer for life in the long term.
We do use it in very specific applications with fail safes in place, typically engines with no other intercooling options.
I attribute meth injection success to Casino Success, you never hear when they lose, but always hear when they win.
Been in the business 36 years I can't tell you how many calls I have received, my meth system failed and took out my motor from either self or other shop builds.
Can it work, Yes, can you win at the Casino yes, but the odds are stacked against you.
There are so many other ways to make power reliably that do not introduce as much risk.
If you are a fan, Great! go for it.
Just don't push a non gambler to go to the casino with false promises.
Ted.
www.jannettyracing.com
email tedj@jannettyracing.com
Old 10-21-2023, 08:45 AM   #7
JANNETTYRACING
Originally Posted by Kerry View Post
Or I run out of meth or my nozzle stops up or the line comes off
What if my jms booster quits to my low side.
On and on,
well now its covered with a 99% fool proof way to protect the car. Don't even need to read an afr or lambda gauge or none of that no red green light, nada!!
Its as automatic as the 10 speed.
I love it!!!!
As I recall you lost a motor already.
Old 10-21-2023, 09:25 AM   #8
Dynamical
Dynamical's Avatar
Ted.
Thanks I appreciate that. E85 isn't practical for me so what other choice would I have if going FI in the future other than meth? The last shop who did most of the build on my old 01SS uses/has used meth for a long time and always had great success. Won't mention any names but they are a VERY popular shop. With E85 not being so widely available up here, Meth seems like the go to but maybe I'm wrong.
I think we'll be talking in the near future. I'm in CT very close to the casinos but I'm not a gambler and trust me nobody would make me do that But I am about an hr away from your shop so maybe I can win there
Thanks again for the info
Old 10-21-2023, 09:33 AM   #9
JANNETTYRACING
Run a combination that is reliable on 91 octane and we have 93 octane.
I have a 700 RWHP combo that needs no meth injection.
Ted.
Old 10-21-2023, 09:52 AM   #10
KingLT1
KingLT1's Avatar
Order a barrel of E98 and blend it with your pump gas. E50-E60 is plenty of octane.
Or do a cam to bleed off some dynamic compression and 93 octane will work better. The thing for me is I would have a hard time tearing the engine down for a cam install since it has to basically be torn down to the short block anyway and not do lower compression forged pistons. Jenetty's 700whp 93 combo does work but you are pretty much capped off at that power level if you leave the stock pistons in it. So if you ever want more, then it's coming back apart again for pistons/rods.
Old 10-21-2023, 10:03 AM   #11
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Agreed. If you have to run 93, running the drop in forged pistons is a no brainer (with the lowered compression). I haven’t run my car on 93 only in a long time, but last check I made ~840 WHP on 93 and that was with my old 2.9 Whipple.
All that said…even a blend of E is SO worth the aggravation. I’m able to make the power number in my signature at “only” E50. And with at least E50, you could run the stock bottom end for a long time at say 650-700 WHP.
Old 10-21-2023, 10:20 AM   #12
JANNETTYRACING
We know Kerry you are the exception to the rule.
Old 10-21-2023, 02:46 PM   #13
WiggyB
WiggyB's Avatar
Drives: 2022 Camaro 2SS 1LE
U know it looks like folks would be happy someone found a, well i guess to me simple way for about I think im 310.00 dollars in to keep a car safe.
Its just me I guess Im a werido ha
I was thinking about adding a JMS for safety measure myself. Anything to keep me out of the engine will do me good. It may add a few ponies to the end result but honestly whatever helps.
d1sc w/ stage 2 intercooler, Lt4 fueling, JMS BAP, lt2 intake, mamo ptb, kooks 1/78 longtube headers w/ h/f cats, alky meth kit, thpsi port injection
WiggyB is offline   Reply With Quote
Old 10-23-2023, 03:11 PM   #14
JANNETTYRACING
Just asking
Never said you did, my reply was not to you.
