The Nights Watch
Inital oil changes
I know this has been debated about needing to change the oil at 500 and 1500 miles and I could not find where I had read that. I finally found a document that states it.
Section 1 Engine Oil Maintenance Check engine oil with every refueling and add if necessary (oil and fuel consumption may be higher than normal during the first 1,500 miles) Please note: It is recommended that the first oil change occur at 500 miles. https://www.chevrolet.com/content/da...ackPREP-R3.pdf
Ordered 22 ZL1 Vert M6 Wild Cherry
2000 19 Jul 2021 3000 21 Jul 2021 TPW 8/23 24 Jul 2021 3400 30 Jul 2021 3800 26 Aug 2021 4000 1 Sep 2021 6000 14 Sep 2021 57 Days from accepted order to delivery. 19 Days from build to delivery. |
![]() ![]() ![]() ![]() ![]() Drives: 2020 Chevy Camaro ZL1 Join Date: Apr 2023
Beautiful vert! (Yes I know about the vert debate) please do the 500 and 1500 oil change and at the very least do your first dump and fill on the rear differential at the 1500 if you plan on keeping this car. If you’re not the original owner, hopefully there is service documents.
