![]() Drives: 2024 2SS vert w/M6 & Dual Mode. Red Join Date: May 2023
2024 Camaro6 Manual Missing Info
Need an illustration showing the exact location of undercarriage pinch welds recommended as lift points on the 2024(2016-24) convertible. Nothing in the manual, zero mention of any jacking points.
I'm aware of the ZL-1 addons and other requirements from Camaro6 forum and the web. |
OSCM(SW) USN Ret.
Drives: 2023 Camaro 2SS-1LE VOM 6M Join Date: Apr 2023
The manual will not tell you. About at the door hinge behind the front tires, in front of the rear tires. Crawl under and you will see the pinch welds.
2023 2SS-1LE VOM, 6M, SR S-TBrace, A-PDL's, Fuzzy suede KP's, NAV
1100 3/29/23 2000 3/30/23 3300 5/1/23 3800 5/4/23 4200 6/1/23 6000 6/6/23 |
![]() Drives: 2017 2SS F1FTY Join Date: Feb 2020
Perform a search of the forum.
2017 2SS F1FTY/HUD/Mag Ride/NPP/Nav/M6/Mishimoto catch can/BTR stage 2 Cam kit/GPI ported LT2 IM and 95mm TB/Roto Fab CAI/Kooks Long Tubes ceramic coated/Borla S Type NPP catback/AFE lowering springs/1LE wheels/OEM smoked tail lights/Diode Dynamics side markers/Uniden R7/3D Maxpider floor mats/Adams graphene ceramic coat
2020 Shadow Gray 2SS
Look underneath, you will see where there are cutouts in the vinyl lower body panel are... That is where you want to lift...
After delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Pedals, SS Wheel Caps, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF-Full Front & Rockers, 35% Tint, CeramicPro coated, RST Stainless Brake Lines, Castrol SRF, MSD Plug Wires, Mamo V3 Ported TB Left: My "fun" ride (475 HP). Right: My "work" ride (52,000 HP): a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph. BOTH AWESOME to operate... |
#5 | |
Brutal
The search engine of this forum is an absolute negative legend, one of the worst I've ever used. That said, using an internet search engine and adding the "site:camaro6.com" tag is way more useful. Quote:
735 rwhp | 665 rwtq Magnuson TVS 2300 80mm pulley | Kooks 1 7/8" LT headers | JRE smooth idle Terminator cam | LT4 FS & injectors | TSP forged pistons & rods JMS PowerMAX | DSX flex fuel kit | Roto-Fab CAI | Soler 95mm LT5 TB | 1LE wheels | 1LE brakes | BMR rear cradle lockout | JRE custom tune 1100 - 1/30/18 | 2000 - 1/31/18 3000 - 2/06/18 TPW 2/26/18 3400 - 2/19/18 | 3800 - 2/26/18 4300 - 2/27/18 | 4B00 - 3/01/18 4200 - 3/05/18 | 4800 - 3/14/18 5000 - 3/16/18 | 6000 - 3/19/18 Last edited by arpad_m; 10-18-2023 at 11:14 PM. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 1SS 6spd Join Date: Jan 2011
I was about to say, "thank goodness! I've been using the diff as a lift point for a while but wasn't sure if it was safe". However, isn't the diagram indicating that cross member at the front of the car as a 5th lift point?
#7 | |
To avoid misunderstandings, I've edited my post above.
#8 |
Appreciate everyone's help. The vert is unique being that it has underbody cross bracing which presents interference issues.
Speaking of manuals, it's been awhile but does Helm still print them for GM vehicles ? |
#9 | |
Unfortunately, Helm stopped offering service manuals with model year 2018, they only have the printed versions of owner's manuals and other downloadable PDFs for the 2019+. The only official shop information source I know of is an ACDelco TDS subscription.
#10 |
Hot Camaro
In a nutshell, the car has six pinch weld points - one directly behind each front wheel, one directly in front of each rear wheel, and one additional one about a foot back from the forward one mentioned earlier.
On the 'vert (deal with it), the one forward and rear are accessible while the "middle ones" are blocked by the cross braces. |
#11 |
![]() Drives: 24 Camaro 2ss 1le M6 Riptide Join Date: Aug 2023
Saw this recently with all the lift/ jack points marked
Ordered: 2024 2ss coupe 1LE Riptide
Placed 8/29/23 1100 9/29/23 - 9/30/23 found and picked up same car in stead 10/5/23 order still at 1100 |
#12 |
![]() ![]() ![]() ![]() ![]() Drives: 2020 Chevy Camaro ZL1 Join Date: Apr 2023
I think the ones circled in yellow are production line mounts, and not meant to be lifted there, I have seen pictures of damage from using that point to lift the car
#13 |
Hot Camaro
I've read similar, potentially when the car is being painted and there's basically no weight from anything IN or ON the car. The green circles are the only points to lift the car once fully assembled whether via a jack or a lift.
#14 |
Thanks arpad_n !
