Old 10-18-2023, 08:43 AM   #1
Nataphen
Drives: None
LPE Low Side Check Valve
I’m gathering all my odds and ends for when I start working on this thing and I was curious if anyone has proven that the LPE high flow check valve can be helpful. I’ll be running the Katech dual pump low side, stock HPFP and injectors, and stock cam. I’m not planning to upgrade the fuel pump lobe unless I ever have to change the oil pump, lifters, or anything else I may need to open it up for. Final plans for now are Kong X port with stock pulleys, bolt-ons with GESI catted headers, and as much ethanol content as possible. I haven’t found any definitive information on how well the valve upgrade works. Will it give me a little help maintaining HPFP pressure? Thanks.
Nataphen is offline   Reply With Quote
Old 10-18-2023, 08:54 AM   #2
Katech_Zach
Katech_Zach's Avatar
Drives: 14 Camaro SS 1LE
I would suggest running XDI 30% over injectors, it will help get through the HPFP falling off.
When I tested a large -10an check valve to replace the factory integrated check valve, I did not gain any improvement around 900rwhp on E85 (attempt to run this). At your power level, I would not worry about it right now.
Katech_Zach is offline   Reply With Quote
Old 10-18-2023, 09:03 AM   #3
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
^agree
Old 10-18-2023, 09:15 AM   #4
Nataphen
Drives: None
I’ve been considering the +30% injectors too, so I appreciate confirmation that it’s worth it on this setup. Thanks so much for the help.
Old 10-18-2023, 09:23 AM   #5
Rapid_blue_zl1_22
See you at the Track!
Rapid_blue_zl1_22's Avatar
Drives: 2022 Rapid Blue SS 1LE
Sounds like you are going to have an almost identical setup as me. The only thing different is the GESI cats, but I've been wanting to order a set for street driving. My goal is also as much ethanol as possible for track use.
2022 M6 Rapid Blue 1SS 1LE PDR (Current)
2022 M6 Rapid Blue ZL1 (SOLD)
Rapid_blue_zl1_22 is offline   Reply With Quote
Old 10-18-2023, 09:31 AM   #6
Nataphen
Drives: None
My track event attendance these days is nonexistent, but maybe one day I’ll get back to it. I mainly just hate jacking with blending. Lol
Old 10-18-2023, 09:47 AM   #7
Rapid_blue_zl1_22
I will actually be in your area next weekend. I will be attending the NASA track day at MSR Cresson on the 28-29th. Let me know if you want to drop by, always nice to meet other enthusiasts!
Old 10-18-2023, 10:02 AM   #8
Nataphen
Drives: None
The two stations near me are E60-E70 year round, so that will be helpful, but I will keep those things in mind moving forward. I always have gauges mounted with fuel pressures, AFR, knock, various temps, etc. when I start tuning, so I’ll keep a close eye on it all. If necessary, maybe DSX’s forthcoming PI with OEM controls will be on my list. I’m fine with that, I just don’t like aux controllers. I want the ECM to know what’s going on with everything.
Old 10-18-2023, 10:03 AM   #9
Nataphen
Drives: None
MSR is a nice track. I won’t be able to make it out, but I’m sure you’ll have a blast. Tons of good people out there to chat with.
Old 10-18-2023, 10:11 AM   #10
XXX ZL1
XXX ZL1's Avatar
Drives: 2024 ZL1 M6
This is what the anti drain valve looks like. Hard to believe it can flow as well as it does. 😂.
2024 Riverside Blue ZL1 M6
Magnuson 2650R, NW 103, Roto Fab Big Gulp
Kooks 2 inch LT's, Stainless Works Legend NPP
THP Billet Valve Covers, Mighty Mouse Wild CC
Signature Forged 20x10.5/20x11.5, BMR springs,
BMR Cradle lockout, AAD Billet arms
2023 Vivid Orange ZL1 M6 - sold
2019 Riverside Blue ZL1 A10 - sold
XXX ZL1 is offline   Reply With Quote
Old 10-18-2023, 10:33 AM   #11
Nataphen
Drives: None
It does look like it would be a valid concern for sure. Fluid dynamics can be surprising sometimes.
