Old 10-17-2023, 07:15 AM   #1
zx9rmal
zx9rmal's Avatar
Drives: '20 ZL1 M6
Battery
I need a battery for my ZL1. What do you guys recommend for long life and big CCA? Thanks.
Mal
Ft. Lauderdale, FL
'20 Camaro ZL1 M6
'22 Kawasaki ZX-14R
zx9rmal is offline   Reply With Quote
Old 10-17-2023, 07:51 AM   #2
In before the antigravity crowd: https://www.amazon.com/gp/product/B008FWCLHU
Old 10-17-2023, 08:04 AM   #3
Rapid_blue_zl1_22
See you at the Track!
Rapid_blue_zl1_22's Avatar
Drives: 2022 Rapid Blue SS 1LE
Antigravity makes a bad ass battery, but I just don't think I could justify $1k for a battery.
2022 M6 Rapid Blue 1SS 1LE PDR (Current)
2022 M6 Rapid Blue ZL1 (SOLD)
Rapid_blue_zl1_22 is offline   Reply With Quote
Old 10-17-2023, 08:33 AM   #4
hawk02
Coupe Newbie
hawk02's Avatar
I got almost seven years out of the OEM battery. I replaced it just because of its age. It was still holding a charge but I felt that wouldn't be the case much longer.
If you're desperately trying to save weight wherever you can, then the added cost of a lithium-ion battery might be justified. Otherwise stick with the OEM battery.
To back up my point about weight savings, the Corvette ERay will come from the factory with a lithium-ion battery. The Corvette engineers tried to save weight at every possible corner to compensate for the added weight of the electric motor and batteries.
Old 10-17-2023, 08:41 AM   #5
zx9rmal
zx9rmal's Avatar
Drives: '20 ZL1 M6
Thanks for the replies. Antigravity is out. Crazy $$. I got a low battery warning so I'm assuming it's the battery. I'll have the battery tested, and the charging system as well.
I'm sure the unusually hot summer here in S. Florida didn't help.
Mal
Ft. Lauderdale, FL
'20 Camaro ZL1 M6
'22 Kawasaki ZX-14R
Old 10-17-2023, 09:10 AM   #6
Vigilante375
Drives: 2018 Camaro ZL1
How often do you drive your car? I haven't replaced the OEM battery in my 2018 since I bought it new in 2018 with it having nearly 40k miles on it now. I live here in Savannah, GA so similar weather as you in Florida.
I'd go with OEM and call it a day. But if you don't drive it much, I'd put a battery tender on it to help prolong the life of it.
Old 10-17-2023, 09:21 AM   #7
jamala00
jamala00's Avatar
Drives: 2016 Camaro 2SS Hyper Blue Metallic
What... Seriously? No, way...
I've never had an issue with any OEM battery in any of my gm vehicles. I'd never bother with any other battery... for what? I'm going to replace the OEM battery in my '18 Tahoe before winter hits. Not having any issues with it, it's just almost 6 years old now.
jamala00 is offline   Reply With Quote
Old 10-17-2023, 09:24 AM   #8
zx9rmal
zx9rmal's Avatar
Drives: '20 ZL1 M6
It's my daily driver. 22K. Bought it new February, 2020. I'm thinking OEM as well Looks like p/n 88864541. I found it at Summit for $167, but I might get it locally in case of any problems. One of the GM parts sites was $100 more.
Mal
Ft. Lauderdale, FL
'20 Camaro ZL1 M6
'22 Kawasaki ZX-14R
Old 10-17-2023, 09:28 AM   #9
Rapid_blue_zl1_22
Yep...
https://wildhammermotorsports.com/16...SABEgKne_D_BwE
Old 10-17-2023, 09:34 AM   #10
hawk02
Coupe Newbie
hawk02's Avatar
Having the battery in the trunk, although inconvenient, helps shield the battery from excessive heat versus it being under the hood. I firmly believe that's why I got seven years out of mine. Every GM vehicle I've owned with the battery under the hood has had the battery crap out between 4-5 years.
Old 10-17-2023, 09:36 AM   #11
jamala00
jamala00's Avatar
Wow.... I have no words... $1000 for a battery...
So if I'm looking at that right, the anti gravity battery for an auto has a warranty of 5 years and the AC Delco OEM battery has a warranty of 3.5 years. I've never had to replace an AC Delco battery in less then 5 years and even after 5 years when I do replace them, I do it out of maintenance not that they went bad. To each their own, but I'd never do it.
Update: I just tonight replaced the AC Delco battery in my Tahoe. It's the nicest of the options as well... $200. The original battery I just took out had a date on it... 6 years and 1 month old. So for the cost of that one Anitgravity battery I can buy 5 of these AC Delco batteries. If they all last like the OE one did, that is just over 30 years of battery coverage for the same price... Ya, you can keep those Antigravity batteries... LOL
Old 10-17-2023, 06:25 PM   #12
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Fellow FL owner here. 95% chance it's fine and just needs a charge. Just put a charger or tender on it. You might be pleasantly surprised, and it's cheaper to buy a tender for $100 than a battery for $150, and you get a new tool out of the deal
The on-again-off-again charging logic in our cars is way too overprotective (AGM thermals, etc.) and will not charge the battery to full under normal driving conditions in my experience. Some folks have reported that driving with the headlights on will keep the charging circuit switched on more of the time (all of the time?) and do a better job of keeping the battery charged.
Old 10-17-2023, 07:17 PM   #13
JSH
JSH's Avatar
Drives: '20 ZLE
Antigravity 60a and trickle charger
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 10-17-2023, 11:44 PM   #14
Plasar
Drives: 2017 ZL1 Vert M6
FYI, another battery thread with some suggestions.
https://www.camaro6.com/forums/showthread.php?t=609648
Plasar is offline   Reply With Quote
