Old 10-16-2023, 08:52 AM   #1
red_johnny
red_johnny's Avatar
Drives: 2016 Gray 2SS M6
Skar audio subs
Well I finally upgraded my system. I added subs. Used the sub- thump kit and everything else was skar. 2 10’s with the EVL kit. 2000 watt amp. I still need to carpet the plywood and manage the wire under it. Still playing with settings to get the sound I want.
Have pics but can’t get them to upload on my mobile device.
red_johnny is offline   Reply With Quote
Old 10-16-2023, 10:09 PM   #2
SomeGeoffGuy
SomeGeoffGuy's Avatar
Drives: 2023 2SS Convertible
Nice - where did you get the signal - did you get the T-harness from the place you got the box from?
-Geoff
'16 2SS Convertible - White on white, mag-ride, NPP, nav. Sold!
'23 2SS Convertible -Same as above except orange.
SomeGeoffGuy is offline   Reply With Quote
Old 10-17-2023, 04:10 PM   #3
red_johnny
red_johnny's Avatar
-Geoff
I got the T-harness. The box came from Skar with the 10's preloaded and set up for 1 OHM. I got to figure out why the amp is not pushing the subs as hard as it should be. At 2000 watts RMS these should be hitting much harder. I feel as its more like at the 800-1000 range.
Old 10-18-2023, 03:29 PM   #4
Plasar
Drives: 2017 ZL1 Vert M6
red_johnny:
* Sounds like a great plan for more bass.
* I’ve got a ZL1 vert with an upgraded stereo from the stock Bose. I’ve got 600 watts and portable JL 10 inch woofer enclosure. I get enough thump for me.
* With your large enclosure, 2 x 10s, and 2,000 watts, you should be knocking over trees.
* Are you sure you set the gains correctly?
* Are you sure you are getting the current you need for 2,000 watts at 12 volts? I like this guy for installation tips.
https://youtu.be/NixHUNo0YII?si=k2UXROztiM13Y1bp
Plasar is offline   Reply With Quote
Old 10-19-2023, 12:05 PM   #5
SomeGeoffGuy
Originally Posted by Plasar View Post
red_johnny:
Yea, that thing has got to be pulling crazy amperage at 1 ohm!
-Geoff
Old 10-21-2023, 06:51 PM   #6
red_johnny
red_johnny's Avatar
-Geoff
Pretty sure I need a second battery. I will check out that video for
