Old 10-15-2023, 10:28 PM   #1
Eric.18RS
Drives: Chevrolet Camaro
Spark plug gapping question?
Gonna change out my spark plugs, what should i gap them at for best performance?
Eric.18RS is offline   Reply With Quote
Old 10-15-2023, 10:49 PM   #2
dfwcowboy
dfwcowboy's Avatar
Drives: 2024 ZL1 M6, 1969 Cessna Skylane
Unless your engine is modified and/or you are running something other than pump gas, you’re probably better off sticking with the manufacturer’s recommendation
dfwcowboy is offline   Reply With Quote
Old 10-15-2023, 11:22 PM   #3
Eric.18RS
I am fully modified running 93 octane
Old 10-15-2023, 11:38 PM   #4
S.Macias
Monterey County Camaros
S.Macias's Avatar
Drives: 2016 Camaro
OEM stock is fine
Follow us on Instagram @montereycountycamaros
S.Macias is offline   Reply With Quote
Old 10-16-2023, 10:17 AM   #5
ctrlz
Spark plug gap will relate to secondary voltage produced by ignition coil or coil pack.
If you want a "hotter" spark, that means upping the secondary voltage AND opening the gap.
If stock gap is 1.00 mm and it takes 10,000 volts to jump that, then going to a 20,000 V coil will still result in a 10,000 V spark because that's all it takes to jump 1.00 mm.
Old 10-17-2023, 04:31 PM   #6
JKOR
Drives: 2023 1SS 6 speed
Do not gap iridium plugs. Look at them, if they are not smashed, install them.
JKOR is offline   Reply With Quote
