![]() Drives: Chevy Camaro 2SS Join Date: Oct 2020
Not shifting in W.O.T. acceleration..
So I had some issues when I changed to bigger tires on the rear with T/C and stabilitrak. Only solution was to get bigger tires in the front. Now I am riding on 285/35/20 up front and 305/35/20 in the rear. Now when I am doing a pull it almost seems like it hits a wall at 7k rmps before it shifts for about 2-3 secs, then it shifts and goes hard again. Could this be due to the tire increase? I haven't tried changing anything on the tire size on HPtuner.
P.S. Normal driving, even fast acceleration shifts fine, just not in WOT.
2019 2SS D1X/CAM/METH/DROP-INS 800whp on 93/ 890whp/670tq C16
Snackbar Tuning
Drives: 2023 SGM ZL1 Join Date: Oct 2016
Changing tire height is like changing rear gears to an extent.
Did you adjust just tire height using the gear/tire wizard in HPT... select adjust speedo and scale transmission?
#4 | |
Just looked into the tune my tuner sent, it does seems like he change the tire size to 28.4 for the 305/35/20 rear. Now I do not know if he scaled the transmission.
