Old 10-12-2023, 07:27 PM   #1
ZeroC
ZeroC's Avatar
Drives: 18 2SS LT4 Top
Koni Yellow Rear Shocks
Hey folks !
has anyone installed the 8241 1315Sport rear shocks yet -- i have a set here everything looks good except the shaft diameter is a little thicker then the oem --bigger is better lol - however the shaft doesn't fit the upper rear mount?
if anyone has installed them yet did you just drill out the mount ?
ZeroC is offline   Reply With Quote
Old 10-13-2023, 06:54 PM   #2
ZeroC
ZeroC's Avatar
in case anyone does a search for this one day - the answer from koni was to drill the mounts to 12mm
Old 10-23-2023, 12:54 PM   #3
greenz28
Drives: 2020 Camaro 1SS M6, Ford Fiesta ST
Good to know because these may be in my future.
Koni has conflicting info on their website I think. One place says comfort is higher than OEM. Another place on the website says they're damping range is a fair bit higher than OEM.
I realize it probably depends on how far you adjust the dampening knob but... Do the Konis ride smoother than OEM? Or, do they ride like super performance stiff?
greenz28 is offline   Reply With Quote
Old 01-25-2024, 07:12 PM   #4
bandier
Got mine!
bandier's Avatar
Drives: 2021 LT1 RS - Orange Crush
I had Koni yellows on my 2010 Camaro. It was lowered with Eibach springs. The ride was perfect and nice. I kept them on the softest setting. Felt like a good firm stock setting to me. After 2 years of running them it seemed like any pothole I hit was teeth jarring. From then on, I desperately tried to avoid potholes. Not sure why all of a sudden the change in shock performance.
Camaro lover since 1984 when I got my first car a 1978 Camaro LT with a 2 barrel carb on 305 V8... yes I put in a 350 with a 4 barrel.
bandier is offline   Reply With Quote
