Old 10-09-2023, 08:11 PM   #1
AndrewSS
Drives: 2018 Camaro SS 1LE
Exclamation !Help! Losing loads of coolant- broken down
Hello everyone, I have a 2018 Camaro SS 1LE with 80,XXX miles.
Check engine light came on last week. Ran code, P050D and P0300.
Misfire on number 7. Losing excess amounts of coolant and lots of white smoke out of the exhaust.
First thing I did was swap coils on 6 and 7, no change. Then replaced number 7 injector, no change. Now getting more misfires on all cylinders. Then replaced all injectors, no change. Then replaced all spark plugs and wires, no change. I’ve cleared the codes and they return. Coolant residue found in intake manifold gaskets. No coolant in the oil. Starting to believe this is a head gasket issue.
Has anyone else had a similar experience and can offer advice/help? I’m at a total loss here.
Thanks!
AndrewSS is offline   Reply With Quote
Old 10-09-2023, 08:21 PM   #2
SwL_Wildcat
SwL_Wildcat's Avatar
Drives: 2024 ZL1
Did the plug on #7, or any plugs, have coolant on it/them when you pulled it/them out?
SwL_Wildcat is offline   Reply With Quote
Old 10-09-2023, 08:24 PM   #3
AndrewSS
No they didn’t.
Old 10-09-2023, 08:34 PM   #4
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
I’d start with a cooling system pressure test.
Old 10-09-2023, 08:35 PM   #5
AndrewSS
I did a carbon test on the coolant reservoir it was positive
Old 10-09-2023, 09:09 PM   #6
Joshinator99
Moderator
Pull the heads and have them checked for cracks and resurfaced. Then reinstall with new head gaskets.
Old 10-09-2023, 09:24 PM   #7
JVERMETTE
JVERMETTE's Avatar
Drives: 22 ZL1
white smoke out the exhaust is usually signs of head gasket failure. Either way, take the car to someone that works on heads and engines before there are further issues or you risk damaging the engine further as coolant travels to areas it should not be in.
JVERMETTE is offline   Reply With Quote
Old 10-09-2023, 09:33 PM   #8
NiickySaz
NiickySaz's Avatar
Drives: 2023 Camaro 1LT V6
If coolant is going to other places. Check the oil and see if it's discolored. Could be a gasket issue with the white smoke. Compression test? Maybe a bad valve seal? Some early LT's had valve spring issues, but I think that was in 2020.
NiickySaz is offline   Reply With Quote
Old 10-10-2023, 12:21 AM   #9
MyNameIs
Drives: Camaro SS
Thanks!
Blown head gasket or cracked head maybe. Getting coolant in your cylinders, reason for white smoke.
MyNameIs is offline   Reply With Quote
Old 10-10-2023, 09:22 AM   #10
AndrewSS
Will do thanks.
Old 10-10-2023, 09:23 AM   #11
AndrewSS
I’m afraid you’re right, thats the issue. Thanks
Old 10-10-2023, 09:39 AM   #12
Briland_1LE
Briland_1LE's Avatar
Drives: 2020 Camaro SS 1LE
Let us know what the problem specifically is I'm always interested in hearing about things that break to watch out for. Is your car stock?
Briland_1LE is offline   Reply With Quote
Old 10-10-2023, 09:40 AM   #13
AndrewSS
Will do! It has a cold air intake and 2ed cats cut out.
Old 10-10-2023, 02:38 PM   #14
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Thanks!
Failed head gasket or a hole in an expensive metal part where it doesn't belong.
broken, codes, coolant leak, injectors, smoke
